B16 smoke
Old Oct 4, 2004 | 10:33 PM
binxers's Avatar
Default B16 smoke
In my b16 hatch if I roll down a hill in gear just letting the compression hold me back then push the gas after a few seconds I get large clouds of blue(oil) smoke. Any Ideas where I'm leaking?
Old Oct 11, 2004 | 11:54 AM
All-MotorSports's Avatar
Default Re: B16 smoke (binxers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by binxers &raquo;</TD></TR><TR><TD CLASS="quote">In my b16 hatch if I roll down a hill in gear just letting the compression hold me back then push the gas after a few seconds I get large clouds of blue(oil) smoke. Any Ideas where I'm leaking?</TD></TR></TABLE>
The tech forum might provide more responses.
Old Oct 11, 2004 | 12:11 PM
x00gsr's Avatar
SEAFOAM the car!!
Old Oct 11, 2004 | 12:22 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (x00gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr &raquo;</TD></TR><TR><TD CLASS="quote">SEAFOAM the car!! </TD></TR></TABLE>
lol....well I'd do a compression test at the very least, or ideally a leak down test to see what's going on in there...it's either a ring or valve seal issue.
Old Oct 11, 2004 | 01:42 PM
x00gsr's Avatar
Im serious, seafoam the car. I have a b16 and it use to puff out black smoke. Ever since i seafoamed it. Not a puff since.
Old Oct 11, 2004 | 01:51 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr &raquo;</TD></TR><TR><TD CLASS="quote">Im serious, seafoam the car. I have a b16 and it use to puff out black smoke. Ever since i seafoamed it. Not a puff since.</TD></TR></TABLE>
yep, but notice he said BLUE smoke, not black..
Old Oct 11, 2004 | 02:34 PM
ham's Avatar
ham
seafoam wont fix a car thats burning a significant amount of oil...
Old Oct 11, 2004 | 02:59 PM
Default Re: (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
lol....well I'd do a compression test at the very least, or ideally a leak down test to see what's going on in there...it's either a ring or valve seal issue.</TD></TR></TABLE>
Compression test showed 217-220 psi on all 4 cylinders on Saturday, so I'm not sure what else it could be if it's not a valve seal issue.
Old Oct 11, 2004 | 06:21 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (All-MotorSports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-MotorSports &raquo;</TD></TR><TR><TD CLASS="quote">
Compression test showed 217-220 psi on all 4 cylinders on Saturday, so I'm not sure what else it could be if it's not a valve seal issue.</TD></TR></TABLE>
Does the car puff blue smoke when starting it up first thing in the morning or when it's been sitting for a while? That would be an indication of valve seals needing replacement. Other than that, has the engine been rebuilt before?
Old Oct 11, 2004 | 06:25 PM
dogfood's Avatar
I agree with the man above, smoke on startup it's the guides, other than that I would have to say it's the rings. sorry bro
Old Oct 11, 2004 | 06:58 PM
ej0513's Avatar
if you compression is good as it shows.. i would think its the vavle guides.
Old Oct 11, 2004 | 07:43 PM
Does the car puff blue smoke when starting it up first thing in the morning or when it's been sitting for a while? That would be an indication of valve seals needing replacement. Other than that, has the engine been rebuilt before? </TD></TR></TABLE>
I'm not sure. It's not my car, so all I know for sure is what the compression #'s were this weekend.
No, the engine has not been rebuilt. It's a stock B16A2 block mated to a B18C1 head w/ a CTR intake cam.
Old Oct 12, 2004 | 09:40 PM
binxers's Avatar
ha ha thanks chris for doing all my replies for me, i've been out of town for a while! the car smokes only after compressing down hill, thats it. its blue smoke not black ( oil not gas ). It doesn't smoke at start-up and my oil levels are not changing much. I'm thinking (along with board of advisers) valve guides, i just wonder if anyone has seen similar instances?
Old Oct 13, 2004 | 03:01 PM
Default Re: (binxers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by binxers &raquo;</TD></TR><TR><TD CLASS="quote">ha ha thanks chris for doing all my replies for me, i've been out of town for a while! the car smokes only after compressing down hill, thats it. its blue smoke not black ( oil not gas ). It doesn't smoke at start-up and my oil levels are not changing much. I'm thinking (along with board of advisers) valve guides, i just wonder if anyone has seen similar instances?</TD></TR></TABLE>
Sorry about that. You weren't replying, so I figured I'd jump in there for you.
Old Oct 13, 2004 | 06:06 PM
ham's Avatar
ham
change the valve guide seals or throw on another head. i had a few motors do that and it was always the valve seals.
jordan_civic
Feb 12, 2008 01:38 PM
Mr EJ1 203
Apr 8, 2006 08:40 AM
hatchy54
11
Aug 3, 2005 09:25 AM
silent-chris
Jan 27, 2005 05:07 PM
binxers
Oct 18, 2004 10:39 PM
