relevance of coil bind
Old Oct 4, 2004 | 10:03 PM
EMphaticONE's Avatar
Default relevance of coil bind
I was researching the different seat pressures and bind extremities on the different valve springs that i plan on putting in my B16A2 w/CTR cams. Since its just cams w/gears, a mild setup (if that), I was wondering what the significance of the coil binding distance is. Also, the Omni springs have a seat pressure of 55lbs while the ITR has 65lbs or pressure, which is best for my setup? What rpm does the CTR stop making power at? TIA.
h0nda n00b
10
Aug 23, 2013 05:58 PM
TB123
Jun 16, 2010 04:25 PM
vannak_5415
Oct 16, 2008 11:46 PM
