p28 ecu in ED6
I'm going obd 1. I need a chip and a dizzy plug and then I can begin.
Since the soldering gun will be out I'll also be cleaning up the wiring from my swap.
My goal is to do a factory style install. Every plug will be gray and all wiring will have the factory look.
The p28 ecu I purchased doesn't fit like the pr3 did.
It's smaller, as a result only two of the four nuts can be used to mount in the factory location.
How did you install your obd 1 ecu in your car? I know you can just set it on the floor or use two of the factory mounts. Any other ideas?
Maxthepersonz
Engine Management and Tuning
Jun 12, 2013 03:22 AM
