spoon b16b stroker kit.
Old Oct 4, 2004 | 06:24 PM
mikecivichb's Avatar
Default spoon b16b stroker kit.
Will a b16b stroker kit from spoon work in a b16a? thanks
Old Oct 4, 2004 | 06:59 PM
Nerologic's Avatar
yes
Old Oct 4, 2004 | 07:03 PM
ExplicitSpeed's Avatar
Default Re: spoon b16b stroker kit. (mikecivichb)
not sure i think they have there differences and why would you want to do that when you could use a LS crank 1.8L and rods resized and custom pistons bored 2.0L with aftermarket sleeves cheaper!!!!!!
Default Re: (Nerologic)
thank you thats all I wanted to to know.
Old Oct 4, 2004 | 07:05 PM
I was always under the impression a 2.0l stroked would not last long. Also to get it sleeved would cost 900 and custom work. while I could get the spoon stroker kit for 1200
Old Oct 4, 2004 | 07:08 PM
Default Re: (mikecivichb)
why would I got through all that custom work when I could just get a b20 block? I wanted to go spoon because It is a good kit and will withstand high rpms for a expended amount of times being that I autox my car.
Old Oct 4, 2004 | 07:14 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
<FONT SIZE="+4">NO.</FONT>
There is a reason the stroker kit it specified for the B16B and not the B16A: the B16B is a de-stroked B18C bottom end, and therefore the block has the B18's 7mm taller deck height vs. the B16A block.
So no, it does not work.
Old Oct 4, 2004 | 07:23 PM
jaydmcrx's Avatar
Haha im glad somebody said that before i did.
Old Oct 4, 2004 | 09:22 PM
DJ_SaNdOz's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
So no, it does not work.</TD></TR></TABLE>
Old Oct 4, 2004 | 09:25 PM
bossman032's Avatar
Default Re: (DJ_SaNdOz)
he knows that hater
Old Oct 5, 2004 | 12:18 AM
Nerologic's Avatar
Default Re: (bossman032)
i said yes as a fast easy answer, and if u look at the specs of the spoon kit, it would work, with a deck plate if he is going to spend all that money on the stroker kit, whats another few bucks for a deck plate?, but i think with the proper tolerences and claying, u might be able to pull off the kit in a b16 ONLY with a stock gasket and NON-milled head ....
Old Oct 5, 2004 | 12:31 AM
Fobtions's Avatar
i said yes as a fast easy answer, and if u look at the specs of the spoon kit, it would work, with a deck plate if he is going to spend all that money on the stroker kit, whats another few bucks for a deck plate?, but i think with the proper tolerences and claying, u might be able to pull off the kit in a b16 ONLY with a stock gasket and NON-milled head ....</TD></TR></TABLE>
the spoon b16b stroker is just a b18c-r crank, rods , piston combo.
and no u cant use it in your b16a because the deck heights between the b16b block and b16a block is about 1/2 and inch taller.
Old Oct 5, 2004 | 03:55 AM
HamiltonRex's Avatar
Default Re: (Fobtions)
89mm LS crank. Stock pistons, and some... I think when i figured it out the rods had to be 5.05" long. Ill double check.
Presto a stroker. I think it was around 11:1 C/R
-Eric
Old Oct 5, 2004 | 07:19 AM
hahagasdcrx's Avatar
Default Re: (HamiltonRex)
Check out this thread its a kit to stroke your B16a with ls internals.
https://honda-tech.com/zerothread?id=815614
Old Oct 5, 2004 | 07:36 PM
Nerologic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">
and no u cant use it in your b16a because the deck heights between the b16b block and b16a block is about 1/2 and inch taller. </TD></TR></TABLE>
Old Oct 5, 2004 | 08:23 PM
esponet's Avatar
no. spoon b16b strocker kit will not fit on b16a.
but toda offers a strocker kit for b16a
davehewitson
Jul 21, 2005 09:40 AM
DA dude
Jan 10, 2005 07:07 PM
RiCE On IcE 2
Oct 25, 2002 12:15 PM
p-boy
Aug 13, 2002 09:01 AM
