d16z6, in 19 hatch, anyone got a way to make the Radiator fan working???
Old Dec 13, 2001 | 09:15 PM
kranked91dx's Avatar
Default d16z6, in 19 hatch, anyone got a way to make the Radiator fan working???
How can I hook up with the fan??? I change all the wiring for 94 si wiring, don't find a way to solve this Rad fan problem,
electrical schema could be very appreciate,
Old Dec 14, 2001 | 11:02 AM
paulzy's Avatar
Default Re: d16z6, in 19 hatch, anyone got a way to make the Radiator fan working??? (kranked91dx)
hook up a toggle switch to make it manual
Old Dec 14, 2001 | 01:29 PM
Default Re: d16z6, in 19 hatch, anyone got a way to make the Radiator fan working??? (Slow_ass_4dr)
Yhea I thought about this option, or make a little independant electronic circuit with an operatinal amplificator to make it work but I am shure that Their is a more simple way to do the job no??
anyone got help??, would be very appreciate!
Old Dec 14, 2001 | 02:07 PM
Mista Bone's Avatar
D Tranny Guru
Connect the 2 wires to the sender on thermstat fan switch, will need to lengthen.
88-91 have the fan switch on the block near oil pressure switch.
92+ have the switch mounted on the thermo housing.
Old Dec 14, 2001 | 08:45 PM
Default Re: d16z6, in 19 hatch, anyone got a way to make the Radiator fan working??? (Mista Bone)
Big Thank man, You rulez!!!! I will look very attentively at the switch on the 94 housing,
Just have to run a live wire in, here to the swith, reli it to the fan and it will became on when temperature is too high???
Il pay you a someday if it work!!!
Old Dec 14, 2001 | 09:00 PM
JD_B18CDX's Avatar
If ur going to connect to sender switch directly. U need a relay switch.
Sender will burn out if u do because it only handles low current.
Old Dec 14, 2001 | 10:51 PM
Mista Bone's Avatar
D Tranny Guru
us e the wiring already on the engine harness.
Old Dec 15, 2001 | 11:56 AM
Yes This is what I want to do, use the wiring on the present 94 si harness but how can I do it, I need electrical scheme, because I don't know where to start,
therefore, the relai switch for the sender unit seem to be a good Idea,
If anybody got a better idea tell me, I want my Ride to be functionnal asap,
Big thank to everyone
tw142808
Feb 9, 2018 10:12 AM
kirkland08
Mar 5, 2011 01:15 PM
Lloyd Xmas
Apr 14, 2010 09:21 AM
hondaon18's
10
Jun 4, 2007 07:45 PM
jry2598
Aug 24, 2006 11:09 PM
