new motor--reuse old clutch/flywheel?
i just completely rebuilt a b16 for a boost setup. im going to be installing an aftermarket lsd unit in the future and rebuilding the tranny after the turbo kit is put on it. (both within ~10k miles)
question: is there anything wrong with using my old flywheel and clutch since they only have about 12k on them? If there is no problems, should i even bother resuracing the flywheel? (nothing has changed, same tranny, same clutch, same flywheel, just a new bseries motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">i just completely rebuilt a b16 for a boost setup. im going to be installing an aftermarket lsd unit in the future and rebuilding the tranny after the turbo kit is put on it. (both within ~10k miles)
question: is there anything wrong with using my old flywheel and clutch since they only have about 12k on them? If there is no problems, should i even bother resuracing the flywheel? (nothing has changed, same tranny, same clutch, same flywheel, just a new bseries motor)</TD></TR></TABLE> youll be fine, if youre not opening up the tranny no need to resurface the flywheel.
bringing this back from the dead..
just need a quick answer.. do you need to break it in again when you take the flywheel and clutch off and swap it onto the new motor?
thanks in advance.
thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie »</TD></TR><TR><TD CLASS="quote">bringing this back from the dead..
thanks in advance. </TD></TR></TABLE>
no break in needed
no break in needed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power »</TD></TR><TR><TD CLASS="quote">
no break in needed</TD></TR></TABLE>
thanks
thanks
StolenTeg
Aug 3, 2004 10:33 PM
