All Motor Setup
Old Oct 4, 2004 | 12:56 PM
BlueTeg01's Avatar
Default All Motor Setup
Ok guys now I'm decide on doing a all motor setup on my 99 gsr. Heres a list of parts I thought would be good to use:
Skunk 2 CAM Gear
Skunk 2 Stage 1 or 2 cam shafts
Skunk 2 valve springs
Skunk 2 Retianers
Skunk 2 valve set
Skunk 2 obd2 to obd1 conversion Harness
ACL Bearings
Greddy Timing Belt
Aem High Volume Fuel Rail
RC Injectors
OK guys This is my goal. My goal is to have over 200 hp to the wheels. Going to have a custom exhaust and I'm undecided on What I/H combo I want to use! I"m planning on running a 12:1 CR. ANd I'll have the block bored from 1.8 to 2.0! Any help or guidance you guys can give me with my set up would be great!
Also what would be better Stage 1 or stage 2 cams from skunk 2?
Modified by BlueTeg01 at 9:51 PM 10/4/2004
Old Oct 4, 2004 | 01:19 PM
Odiedogcx's Avatar
AIRBORNE
Default Re: All Motor Setup (BlueTeg01)
if you want 200hp .. go with some more agressive cams then the skunk2 stage 1's .. look into Buddy Club Spec III+ cams, and with the valve train, look into Rocket Motorsports or Omnipower (good prices at http://www.kteller.com).
Old Oct 4, 2004 | 04:08 PM
crazzeboost's Avatar
I second that i have heard alot of great stuff about Omnipower, im actually choosing those over the skunk2 valvetrain myself but i think i am also running the Skunk2 Stage 2 cams.
Old Oct 4, 2004 | 04:27 PM
dabig1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg01 &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys now I'm decide on doing a all motor setup on my 99 gsr. Heres a list of parts I thought would be good to use:
Skunk 2 CAM Gear
Skunk 2 Retianers
Skunk 2 valve set
ACL Bearings
Greddy Timing Belt
RC Injectors
OK guys This is my goal. My goal is to have over 200 hp to the wheels. Going to have a custom exhaust and I'm undecided on What I/H combo I want to use! I"m planning on running a 11:1 CR. ANd I'll have the block bored from 1.8 to 2.0! Any help or guidance you guys can give me with my set up would be great!
Also what would be better Stage 1 or stage 2 cams from skunk 2?</TD></TR></TABLE>
you can't bore your block from 1.8 to 2.0,you cant remove that much material.only way would be by stroking it.
Old Oct 4, 2004 | 04:41 PM
HondaGuy02's Avatar
Banned
Default Re: All Motor Setup (dabig1)
sorry man but i gotta do it,
the fast and furious avatar =
Old Oct 4, 2004 | 04:44 PM
HondaGuy02's Avatar
Banned
Default Re: All Motor Setup (HondaGuy02)
but seriously though, do a lot of research... a lot of topics have been covered. I found its better often times to just search under archives then to post a new discussion that might have been covered a million times. You can learn a lot just off of searching but dont believe everything you read, some of it is hear say.
good luck though
Old Oct 4, 2004 | 05:36 PM
brol1k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuy02 &raquo;</TD></TR><TR><TD CLASS="quote">sorry man but i gotta do it,
the fast and furious avatar = </TD></TR></TABLE>
dont put him down like that, it was a simple question for opinions.how did u get on that subject
Old Oct 4, 2004 | 06:09 PM
BlueTeg01's Avatar
Let me rephrase my self for you I'm boring out the cylinder walls to 84mm from the 81mm of the stock walls.
Old Oct 4, 2004 | 06:17 PM
eyeamvic's Avatar
Boring past 82mm without resleeving is a no-no. Boring the sleeves to thin. You would need to resleeve.
Old Oct 4, 2004 | 06:37 PM
BlueTeg01's Avatar
Default Re: (eyeamvic)
They will have darton sleeves......yes I know its a no no any car guy knows that!
Old Oct 4, 2004 | 06:44 PM
eyeamvic's Avatar
Default Re: (BlueTeg01)
Oh, in that case, you're sleeving it, you don't bore. As for that setup, I would suggest a higher compression. 11.6:1 area. Would even be good enough to bump the stage 2 cams. I myself wouldn't do the retainers. The ITR retainers can be taken up to 9500. And don't forget engine management to tune that bish!
Old Oct 4, 2004 | 06:53 PM
BlueTeg01's Avatar
I goofed on my oringinal post I'm wanting to run 12:1 CR. I'm searching about running some stage 2 cams currently! Thanks for the correction on terminology!
Old Oct 4, 2004 | 09:00 PM
AllmotaB18EH2's Avatar
i say you run skunk valve train with stage 2's and get the rev valves just as good as skunk and a lot cheaper and run venom 310 injectors...then you will have power
Old Oct 5, 2004 | 12:03 AM
Odiedogcx's Avatar
AIRBORNE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabig1 &raquo;</TD></TR><TR><TD CLASS="quote">
you can't bore your block from 1.8 to 2.0,you cant remove that much material.only way would be by stroking it.</TD></TR></TABLE>
You can, it just needs to be sleeved.
dominicanyo
Jun 27, 2007 10:38 AM
IggyBcool
16
May 14, 2005 05:57 PM
ActiveAero
Jul 12, 2003 08:29 AM
justmotor13
Mar 17, 2003 05:26 PM
LX4SI2NV
Jan 21, 2003 02:09 PM
