tranny is leaking oil...
Old Oct 4, 2004 | 12:16 PM
cyrock's Avatar
Default tranny is leaking oil...
hi,
i was checking the oil in my motor and i saw a little thing on the floor, oil s leaking from my tranny not a lot but i put my finger and i feel it ... it s comin from where the tranny connect the block .... close to this part tho but more tranny s part
wa ts goin on you think .....my trany has been removed few days ago, and put it back, maybe i saw a bolt is missing ...if guys can help me with pix....it would be great bye
Old Oct 4, 2004 | 12:25 PM
LSvtec03's Avatar
Default Re: tranny is leaking oil... (cyrock)
your tranny doesn't carry oil where it connects to the block. if its by the block that you see the oil, maybe it's coming from the headgasket or valve cover, or just another seal that needs replacing.
try to follow the leak and see where it's coming from
Old Oct 4, 2004 | 12:33 PM
cyrock's Avatar
Default Re: tranny is leaking oil... (LSvtec03)
k i ll check, but i m sure it s from the tranny cause the head gasket is brand new ...
i ll find tho...thx
Old Oct 4, 2004 | 12:55 PM
IN VTEC's Avatar
Smell the oil. If you're using a tranny-specific lube (ie: Honda MTF), the oil will have a sweet, aromatic smell to it.
If the oil is black and smells like exhaust and fuel, then it's motor oil.
Motor oil leak - Check oil pan gasket, distributor gasket, VTEC solenoid gasket, cam seal, and then the rear main seal.
Tranny fluid leak - Check Axle seals.
junk95civ
Feb 26, 2010 03:05 PM
gooberwolf
Dec 24, 2008 08:43 AM
drastikmeasurez
Jul 22, 2005 04:59 PM
crxturboh22
Jan 17, 2004 09:15 PM
