anyone else have the problem with the passenger side window rolling down?
spray some w40!!! it works!!! it happened to me & my girl too~ for driver side tho~
This is a known problem with Integras. I believe there is a Technical Service Bulletin out for this. Take it into the dealer..you should be able to get it fixed for free.
Chris
Chris
1. roll down your window
2. spray some wd-40 on the black weatherstrip all around the window
3. roll your window glass up and down a few times
if the problem not solve yet~
4. remove your door panel
5. spray some wd-40 again on the window glass equalizer arm
the problem still exist ?
6. check with your window motor and regulator
if you need to replace your window motor or regulator then
7. i have one on ebay http://cgi.ebay.com/ebaymotors/aw-cg...ndexURL=0&rd=1
just take the door panel off and check to be sure. i found out on my passenger side window that part of the window was outside of the rubber guides when going up...dont know how that happened but after i fixed it, it goes up/down a lot faster than my driver's side window. oh i also lubed it up a bit w/ wd40.
Same problem. It's the rubber guide down in the door panel. Mine is torn. The window gets stuck when in goes down into this rubber guide. I'm going to replace the rubber guide eventually. I put some light oil down the rubber guides and it works for a day or two, but then it's back to getting stuck.
[Modified by ACIN, 11:27 AM 12/16/2001]
Slammed_am
Nov 14, 2005 11:29 AM
