obd1 fuel injectors
im in the middle of my motor swap and got stuck. they feul injectors are really different from my crx si harness and my cx 92 harness. not sure how to wire it up.
wiring gsr into crx si 1991. going obd1.
Modified by CrxEDguY at 1:35 PM 10/4/2004
the injector clips from the OBD1 harness should be able to plug into them.
Can you take out an injector and get the numbers and any letter from the injector and post them? Maybe you don't have Honda injectors in there.
sorry i meant the wiring between obdo harness and obd1 harness for the injectors are different. for some reason the obd1 harness seems to have alot more ground wires than the crx harness. but the injectors look the same. would it be possible just to plug them in. would they work. they are honda because i used them on the motor before in my eg hatch.
huh?
The inkectors all have 2 wires each.
The OBD-0 takes all the same wire colors and takes them to the injector resistor box. From there, the wire goes to the ECU and that's were the positive connection is made.
The other wire(s) going to each injector is the ground wire. They all go to the ECU.
OBD-1 has just as many wires for the injectors, but no resistor box.
90Rexx
Sep 15, 2010 10:47 AM
crx_si-r
Jun 24, 2008 02:05 PM
ef8sleepr
Feb 23, 2006 09:25 PM
