ACT CLUTCH Problem
Old Oct 4, 2004 | 11:20 AM
hatch4raceb16's Avatar
Default ACT CLUTCH Problem
I have a ACT 6 puck in my 2000 Civic Si and I HATE IT. I also have a 12 lb act flywheel, im going to pull the trans and swap in a exedy organic clutch, basically a stock clutch. Can i leave the act flywheel in there?? Will it cause any problems??
Thanks in advance.
Old Oct 4, 2004 | 01:19 PM
EP3_05's Avatar
Default Re: ACT CLUTCH Problem (hatch4raceb16)
As long as you can resurface the act flywheel then you should be set.
Old Oct 4, 2004 | 01:57 PM
blackeg's Avatar
Default Re: ACT CLUTCH Problem (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">As long as you can resurface the act flywheel then you should be set.</TD></TR></TABLE>
pretty much. why do you hate the 6 puck?
are you making enough torque/hp that you would need it
Old Oct 4, 2004 | 03:24 PM
Default Re: ACT CLUTCH Problem (blackeg)
I hate how it chatters and shakes when i release, i gotta rev to 3k and let it out to make it smooth. also i have read so much that says it beats the crap out of the transmission, and i think its the reason i have a ripped cv boot tht im replacing this weekend with a new axle. so i want something milder.
Old Oct 4, 2004 | 06:23 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch4raceb16 &raquo;</TD></TR><TR><TD CLASS="quote">I hate how it chatters and shakes when i release, i gotta rev to 3k and let it out to make it smooth. also i have read so much that says it beats the crap out of the transmission, and i think its the reason i have a ripped cv boot tht im replacing this weekend with a new axle. so i want something milder.</TD></TR></TABLE>
SO why did you get the 6 puck again? Are you making that much power to justify running one on the street? The Xtreme PP with street disc is plenty for most cars. You'll just have to live with the chatter of a 6 puck because it is basically an on/off type clutch.
Old Oct 4, 2004 | 07:06 PM
Default Re: ACT CLUTCH Problem (iiilgsrlll)
i didnt buy it, the previous owner had it put in, im not making anymore power than a stock b16 with boltons should, but soon to be SC'd or turboed.
Modified by hatch4raceb16 at 9:46 AM 10/6/2004
Old Oct 5, 2004 | 06:21 AM
Old Oct 5, 2004 | 12:11 PM
allmotrjdm's Avatar
the screeching noise could likley be the throughout bearing, i had that problem on my old hatch.
Old Oct 6, 2004 | 08:47 AM
Default Re: ACT CLUTCH Problem (allmotrjdm)
its teh actual clutch, i was learning how to release it correctly
aZnjCC
Mar 6, 2006 07:09 AM
EJ8 GSR-T
Feb 15, 2006 07:50 PM
honcrx91si
May 17, 2004 05:01 PM
jeremy.
10
Oct 29, 2003 11:24 AM
Solipsist
Dec 6, 2002 11:49 AM
