tachometer wiring help
Old Oct 4, 2004 | 07:51 AM
boosted_lude's Avatar
Default tachometer wiring help
installing a Pivot racing tachometer for my little brother 94 integra ls 5spd. i know that the red wire is power, white is rpm signal input, orange is parking light, nad black is ground. well does anyone know which wire behind that gauge cluster is which ones. i am going to to connect the wires to the hareness behind there. can anyone help me identify which wire is power,rpm signal, and parking light.
thanks in advance.
Old Oct 4, 2004 | 10:11 AM
Default Re: tachometer wiring help (boosted_lude)
anyone??
Old Oct 4, 2004 | 10:32 AM
NightStalker-GsR's Avatar
read your instruction manual
Old Oct 4, 2004 | 11:57 AM
Default Re: tachometer wiring help (NightStalker-GsR)
i did, but it just said wat each color was for from the tach. but i'm not sure whick color wire behind the factory gauge cluster is which. it didn't have a diagram in the instruction booklet. i have already checked thier website too.
Old Oct 4, 2004 | 01:12 PM
Old Oct 7, 2004 | 09:45 AM
CleanLikeJdm's Avatar
Hype-R Stalker
negative terminal on the distributor, unless you have a external pack you'll have to wire under the cap.
Thats what i did, but i have a msd external coil-pack.
Old Oct 7, 2004 | 09:25 PM
mnskateboarder's Avatar
i think you can just tap the rpm signal wire into the wire in the upper right of your engine bay if your looking at it from the front of your car? its mounted on a clip and has a wire going to it that dosent lead to anything. that might be easiest. maybe easier to run the wires else where than behind your cluster. good luck.
Old Oct 12, 2004 | 08:04 AM
Default Re: (mnskateboarder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnskateboarder &raquo;</TD></TR><TR><TD CLASS="quote">i think you can just tap the rpm signal wire into the wire in the upper right of your engine bay if your looking at it from the front of your car? its mounted on a clip and has a wire going to it that dosent lead to anything. that might be easiest. maybe easier to run the wires else where than behind your cluster. good luck.</TD></TR></TABLE>
yea i know it is probably easier wire it up the other way. but i want to wire it up behind my cluster. but i don't know which wire is which behind the cluster. so any help in that area would be very appreciated. thanks.
Old Oct 12, 2004 | 01:38 PM
Default Re: (boosted_lude)
anyone...............
Old Oct 12, 2004 | 03:21 PM
whoneedzvtec's Avatar
what i did was tap into where the distributor cap. right behind that u will see a big connector that that harnesses an *** load of different colored wires connect the white one from the tach to the blue one. dont forget to cut the brown and orange wire loops on the back of the tach too
Old Oct 12, 2004 | 08:04 PM
BlueIntegraBoy's Avatar
All the wiring can be done from behind the dash.
1. Red tach wire goes to black/yellow wire behind dash.
2. Orange tach wire goes to red/black wire behind dash.
3. White tach wire goes to blue wire behind dash.
4. Black wire goes to the bolt next to your hood release.
Old Oct 13, 2004 | 05:20 AM
Default Re: (BlueIntegraBoy)
Thank you, BlueIntegraBoy.
Old Oct 13, 2004 | 09:07 PM
NP, what brand tach is it? I know that autometer uses green for the tach signal wire and white as the background lighting.
Old Oct 14, 2004 | 05:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">NP, what brand tach is it? I know that autometer uses green for the tach signal wire and white as the background lighting.</TD></TR></TABLE>
its a pivot racing tach. i use to have it in my prelude awhile back. then gave it away to my little brother. its a small tach not big like the 5" autometer.
Kris' Workshop
Jun 6, 2019 07:19 AM
crazyhouse2011
Jan 1, 2015 02:18 PM
onepoint-gsr
Nov 2, 2006 08:16 AM
SocalChris
Oct 7, 2004 10:32 PM
variable
Jan 28, 2004 12:49 PM
