Bought 00 GSR clean but busted motor!!!
Old Oct 4, 2004 | 06:36 AM
EJ20's Avatar
Default Bought 00 GSR clean but busted motor!!!
On ebay for about 7 G but there was some water damage to the engine. Previous owner says piston 1 is hitting the wall ...If you start the engine up it makes this horrible horrible knocking sound.
engine only has 50k miles! is it worth tearing apart and fixing? Buddy said if one thing goes wrong everything goes wrong so it would cost more to fix it in the end. So he suggests a new motor (jdm perhaps? )
what would be needed for an engine swap? Saw a motor on ebay b18c1 for 2G just engine..would I also need harnesses, motor mounts or anything?
Old Oct 4, 2004 | 07:32 AM
dFreezy's Avatar
Default Re: Bought 00 GSR clean but busted motor!!! (EJ20)
if everything else is in good condition, thats not a bad deal, you could easily swap in a new b18c in there for under $2500. i would be careful if you buy an engine from ebay, check out hmotorsonline.com or passwordjdm.com for reliable engines.
Old Oct 4, 2004 | 07:39 AM
EJ20's Avatar
Default Re: Bought 00 GSR clean but busted motor!!! (dFreezy)
I just thought of this ...wouldnt there be a problem if I buy an old motor and put it into this 2000 Integra...lotta b18c1 motors im seeing on hmotorsonline r pretty old...
Thought it was illegal to put older motors into a newer car...
Old Oct 4, 2004 | 07:52 AM
JDubya's Avatar
Yea I think you're right. You have to put a motor of the same year or newer into your car to be legal.
Old Oct 4, 2004 | 09:10 AM
Copy Cat's Avatar
Default Re: Bought 00 GSR clean but busted motor!!! (ALL MOTOR LS till 4K)
In maryland man they really wont care. With my old car i swapped in an older b16 into my car (00 civic fourdoor) and no one would ever think to even look at the etchings on the motor. Just get the damn thing and put it in there. Our state is not not as bad as california.
Old Oct 4, 2004 | 01:25 PM
EJ20's Avatar
Default Re: Bought 00 GSR clean but busted motor!!! (CivicFerioViRs)
CivicFerio You just made my day
Old Oct 4, 2004 | 01:34 PM
EJ20's Avatar
now what specific parts would I need to look out for when choosing a replacement engine.
http://www.hmotorsonline.com/s...30008
http://www.hmotorsonline.com/s...30009
I'm looking at these two. Do I really need to shell out another $250 to get the complete change over option?
edit:
I should of read closer
seems like complete changeover comes with three extra things
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
And so far I am clueless on if I need these items...I'm also trying to decide if I should get the c5
Modified by EJ20 at 3:15 PM 10/4/2004
Old Oct 4, 2004 | 02:35 PM
RedGSR's Avatar
All you need is just the engine. However, you will have to look for the ODB2 engine.
Old Oct 4, 2004 | 02:57 PM
JBBNJ609's Avatar
take the engine apart as a learning experence and maybe you just have a spung bearing . . thats re buildable and also you can sell or re use the head . . .
Old Oct 4, 2004 | 03:04 PM
crazyteg95's Avatar
hell yeah go for it get it worked on!!!
Old Oct 4, 2004 | 06:29 PM
rovigian's Avatar
Default Re: Bought 00 GSR clean but busted motor!!! (crazyteg95)
Why don't you just buy a b18 longblock, since you don't even need the transmission or anything else.
Old Oct 4, 2004 | 07:28 PM
stareatsun's Avatar
Do not buy off EBAY. Motors are stolen all the time and they sold there. Seriously you will get screwed even more.
Old Oct 4, 2004 | 07:31 PM
Copy Cat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ20 &raquo;</TD></TR><TR><TD CLASS="quote">CivicFerio You just made my day </TD></TR></TABLE>
Glad to hear that man
But seriously i know mad headz with swaps that are not the same year as thier cars. Trust me howard county cops have other things to worry about, like being a bunch of retards and lying to drivers about their speed and giving them tickets
to Ho.Co.Po
chanksta06
Aug 29, 2006 03:53 PM
Capt. Jimbo McSubipants
Aug 1, 2005 10:57 AM
eric8876
Mar 27, 2005 03:01 PM
FormulaGSR
13
Feb 19, 2005 10:11 AM
B_1_8_hatch
18
Mar 10, 2003 07:14 PM
