DIY OEM ITR trunk brace, completed w/ pics.
Old Oct 3, 2004 | 09:31 PM
threatcon13's Avatar
New User
Default DIY OEM ITR trunk brace, completed w/ pics.
I've been wanting to do this for a while. Using GSR-rex's excellent instructions, I finally got around to doing it. First i sanded the trunk brace and then sprayed it w/ a couple of coats of flat black enamel. The only problems I kind of ran into was making the template in the plastic panel, I made the holes rather large because I didnt want to have to do it again in case they were too small. Also, its a pretty darn tight fit when you are holding the nut from underneath the car after the bumper is remounted. Other than that, it was cake. On a side note, don't use craftsman's worst drill to drill the holes in your car, if it wasn't for the bit I had (which cost almost half of the drill's price), I would have definitely lost the battle. Here are some pictures. Thanks again to GSR-rex for his awesome instructions, and egjoe for the brace itself.
Old Oct 3, 2004 | 09:33 PM
iBear's Avatar
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (Threatcon13)
looks pretty good, nice job man
Old Oct 3, 2004 | 09:34 PM
New User
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (EJellyfish1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJellyfish1 &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty good, nice job man </TD></TR></TABLE> thanks, it was a lot of fun. Not a lot of fun taking the bumper off and putting it back on myself however.
Old Oct 3, 2004 | 09:39 PM
Aaron M's Avatar
Xymox007's Avatar
3 bars in the back of the hatch? i guess utlity isn't much of a concern, no?
Old Oct 3, 2004 | 09:41 PM
New User
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">3 bars in the back of the hatch? i guess utlity isn't much of a concern, no?</TD></TR></TABLE> plenty of space in the hatch w/ 3 bars, the c pillar bar comes out in 5 minutes as well, the strut brace comes out in less than 1 minute. I daily drive this car, and use the trunk all the time.
Old Oct 3, 2004 | 09:55 PM
Greenery18's Avatar
Very cool pics. I myself am obsessed with strut bars of any fashion. Are these bars applicable in the Sedan as well? Or is there a different version? tia.
Old Oct 3, 2004 | 09:56 PM
JDubya's Avatar
got a link for the how-to?
Old Oct 3, 2004 | 10:15 PM
New User
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (ALL MOTOR LS till 4K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS till 4K &raquo;</TD></TR><TR><TD CLASS="quote">got a link for the how-to?</TD></TR></TABLE> yes sir, it is right here, page 1 towards the bottom. https://honda-tech.com/zerothread?id=291430
Old Oct 3, 2004 | 10:18 PM
New User
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (Greenery18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">Very cool pics. I myself am obsessed with strut bars of any fashion. Are these bars applicable in the Sedan as well? Or is there a different version? tia.</TD></TR></TABLE> Hmm...honestly I'm not sure if its the same w/ the db8. If you look at this link https://honda-tech.com/zerothread?id=291430 and then take out your rear panel, and if its similar, I'm pretty sure it will work. The only way to really know I guess is to find out if the JDM 4 door ITR came w/ one stock. But even if it didn't there should be a way to make it work.
Old Jan 2, 2006 | 10:19 PM
ITR#23(01silverdc2)'s Avatar
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (threatcon13)
when doing this trunk brace .....i took the panel off and the bar doesn't match up to any of the factory holes?you had to drill the holes to use this oem trunk bar?
Old Jan 2, 2006 | 10:44 PM
sittingonROTAS's Avatar
76.216.10.150
whats it do?
Old Jan 2, 2006 | 10:47 PM
SpoonTeg's Avatar
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (01SILVERDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01SILVERDC2 &raquo;</TD></TR><TR><TD CLASS="quote">when doing this trunk brace .....i took the panel off and the bar doesn't match up to any of the factory holes?you had to drill the holes to use this oem trunk bar?</TD></TR></TABLE>
yes!
good pics here!
http://www.geocities.com/bretq....html
Old Jan 2, 2006 | 11:14 PM
gsrious's Avatar
is that mugen strut rear tower bar made for integra... or is it for civic? just wondering because you had to make such a big cut.
Old Jan 2, 2006 | 11:17 PM
Dartanian's Avatar
Default Re: (sittingonROTAS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sittingonROTAS &raquo;</TD></TR><TR><TD CLASS="quote">whats it do?</TD></TR></TABLE>
Yeah, I am wondering the same thing....does it do anything?
Old Jan 2, 2006 | 11:41 PM
SpoonTeg's Avatar
Default Re: (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, I am wondering the same thing....does it do anything?</TD></TR></TABLE>
if any, its probably as much help as the RLTB or the c pillar bars...=T
but it adds up! PLUS, it looks cool
Old Jan 3, 2006 | 02:09 AM
enphotography's Avatar
Very nice write up, now saved and hope to do this to my ride..
Old Jan 3, 2006 | 05:50 AM
reno96teg's Avatar
have you guys noticed any difference with this mod? honestly, it seems to me that it wouldn't do much of anything.
Old Jan 3, 2006 | 06:42 AM
blackdelslo's Avatar
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (reno96teg)
I wouldnt even mess around with that type r trunk brace, if your going to do something in the trunk, do a triangle connecting the strut towers and the rear trunk.
Old Jan 3, 2006 | 09:06 AM
RGoose18's Avatar
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (delLudeVTEC)
You guys are pretty much wasting your time and money doing this mod. I took this bar out of my Type R while I was doing some interior cleaning and forgot to put it back in, it sat in my garage for 2 years. I absolutely never felt even the slightest difference. Maybe in theory it works, but for real world applications, I would put the money into a more usefull mod, like tires.
For those looking for a performance mod, stay away from this one, for those who want to get their POS as close as possible to an R, pay up, because that's all you'll be doing
Old Jan 3, 2006 | 09:43 AM
TunerN00b's Avatar
Default Re: DIY OEM ITR trunk brace, completed w/ pics. (RGoose18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">You guys are pretty much wasting your time and money doing this mod. I took this bar out of my Type R while I was doing some interior cleaning and forgot to put it back in, it sat in my garage for 2 years. I absolutely never felt even the slightest difference. Maybe in theory it works, but for real world applications, I would put the money into a more usefull mod, like tires.
For those looking for a performance mod, stay away from this one, for those who want to get their POS as close as possible to an R, pay up, because that's all you'll be doing </TD></TR></TABLE>
First off, I don't have any supporting facts, so this is just my opinion. But I will have to disagree with this statement.
If the bar didn't add any benefit, then I seriously doubt Honda would have put a brace there stock on the Type-R. I'm not falling for the "its an itr, it must be fast" crap, I'm just saying. Honda created the itr to be better, (mild port and polish, cams, factory header, chassis reinforcement, stiffer springs and rear swaybar) and I doubt they would have spent the money on a brace if it didn't make a difference, especially for a brace that isn't visible bling.
Then again, an otherwise stock gsr or ls might not benefit as much. Without the rest of the handling improvements, the gain might be minimal. Now, I'm personally running my gsr on 400/400 springs, and I could definately feel the difference when I put the stock front strut bar back on (it was off to modify it to fit around the GC top hats), but it was only noticeable during autocross, and only really for turn in. So chassis stiffening probably isn't the best way to improve a car's handling, but any gain is gain. I would only look into it after better springs, shocks, and tires are already on the car.
Old Jan 3, 2006 | 10:15 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">You guys are pretty much wasting your time and money doing this mod. Maybe in theory it works, but for real world applications, I would put the money into a more usefull mod, like tires.
I followed Brets diy trunk bar...only costed me about 13 bucks. but youre right, i cant really tell any improvements or such with this bar...but maybe its bc i have a itr sway bar too
Old Jan 3, 2006 | 10:21 AM
jomama's Avatar
nice write up
ITR 05082
Dec 7, 2009 09:02 AM
Beasty18C5
Apr 3, 2009 07:50 PM
austrian type-R
Jan 19, 2004 10:22 PM
gsr-2nr
Nov 5, 2003 11:10 AM
Pineapple Devil
Jan 19, 2003 06:27 AM
