gsr block with ls crank... which rods?
Old Oct 3, 2004 | 09:27 PM
cornhusker's Avatar
Default gsr block with ls crank... which rods?
when i rebuild my gsr block, i am planning on used an ls crank, but i am a little unclear on a couple of things. first, which rods? i am almost 99% sure the answer is ls rods, but i just wanna confirm. are there any other issues that i should be aware of? lemme know, thanks.
Old Oct 3, 2004 | 10:16 PM
93lsd's Avatar
Default Re: gsr block with ls crank... which rods? (cornhusker)
you will use the ls rods and you will have too block off the oil squirters bacause the counter weights will hit the, but other than than that you will be fine
i would also use acl bearings
Old Oct 4, 2004 | 02:58 PM
cornhusker's Avatar
Default Re: gsr block with ls crank... which rods? (93lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote">you will use the ls rods and you will have too block off the oil squirters bacause the counter weights will hit the, but other than than that you will be fine
i would also use acl bearings </TD></TR></TABLE>
what if i go with aftermarket rods like eagle or crower, will i still lose the oil squirters?
dem0nk1d
Feb 4, 2007 01:32 PM
vtec-gorilla
Sep 19, 2006 06:40 PM
methodz55
11
Mar 12, 2005 08:46 AM
NathanMorris
Nov 30, 2004 10:01 AM
JBBNJ609
Oct 20, 2004 08:05 AM
