Clutch Switch Bypass
I searched, found tons of post's about it, but no one said which exact wires to splice together to eliminate it.
My switch just fucked up, I need to bypass it rather than replace it. I found a diagram but I dont understand it. Im in Florida, bad misqotos due to the recents hiurricanes, and my car wont start.
Someone please help me. I took my seat out to get under the dash easier and it still sucks *** down there.
Help me ASAP people!
there is usually two wires near the top of the clutch, that is the switch that determines when the clutch is pressed. If you get under there and hit the clutch and listen ofr the switch that should lead you to it. Once you find it you normally just have to jump the leads on it... (I install autostarts and thats what its like on most manuals, just transfers ground from one wire to the other).
Thats the thing. Its so cramped under there that I can't make anything out bro.
I was figuring maybe the wires led a little lower into the dash area where I could work a little easier, and then if someone could tell me which wire colors it was.
Get under the dash, fallow the Clutch peddle. Fallow the cable. there should be only one electronic switch on it. And thats the clutch switch. And on my car the clutch has to be touching the carpet before the Car can start.
Fixed it. I can see the switch fine, but not the wiring... maybe an 89 sedan has a few more things cluttering the area up?
Anwyays, just wedged a bolt in the hole where it usually plunges, works great... did it to my brake light switch a while back.... now it will never budge mwhahah..
Thanks for the help guys!
I got bit by 1 million mosquitos.
Ya man, its bad... but ****, when you dont got your car... it sucks even more. I missed a hot date last night because of it... never again LOL.
I apprciate the help that H-T has given me!
