OBD0 Knock sensor questions
I recently swapped in a b16 from Osaka motors ( no broken sensors
) and theres a few things I wanna say.
1) vtec pwns j00
2) I beat an evo eariler tonight
heh, question time. ECU ( PR3 ) throws a code 23. Knock sensor, but it only throws the code during the day. Ive rechecked all the wiring and everything matchs up. The weird thing is that it doesnt throw the code at night.. Only during the day, and vtec still kicks in even though its a vtec code. It comes on randomly, ive tried resetting it numerous times..
Thoughts?
) and theres a few things I wanna say.1) vtec pwns j00
Thoughts?
Needs to be About 20% Cooler
i'm herd of instances where the EFI (electromagnetic feild interferiance) generated by the curent in ur hedlights goes into the knocksensor wire at the firewall bundle and gives the ecu a crazy signal so it thorws a code. try running the car with out hedlights
at night. i know it's crazy but i'd bet u woulding get a code if that works u can try puting a shealded wire on to protect against EFI
having same problems...had the code for over a year now, even replaced my knock sensor. Funny thing, I had my knock sensor hooked up temporarily strapped inside the car and grounded, no codes for about 6 months...had car dynotuned, then knock sensor code appeared. Permanently installed the knock sensor to the block, replaced with shielded wires, still get code. Another weird thing, the knock sensor code appears only when the motor is hot...like when I start the car in the morning on my way to work, no codes up until I drive a few blocks away and my temp gauge goes up a notch, then the knock sensor code appears.
*set up, lsvtec motor, ecu (PR3/Stage2 Hondata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">having same problems...had the code for over a year now, even replaced my knock sensor. Funny thing, I had my knock sensor hooked up temporarily strapped inside the car and grounded, no codes for about 6 months...had car dynotuned, then knock sensor code appeared. Permanently installed the knock sensor to the block, replaced with shielded wires, still get code. Another weird thing, the knock sensor code appears only when the motor is hot...like when I start the car in the morning on my way to work, no codes up until I drive a few blocks away and my temp gauge goes up a notch, then the knock sensor code appears.
*set up, lsvtec motor, ecu (PR3/Stage2 Hondata)</TD></TR></TABLE>
On hondata stage 2 u have it reading ur knock sensor right, cause with hondata stage two u dun even need the actual sensor u can program i think .. lol mine is strapped to the back of motor just chillin.. Mines fine no pinging, i use 93 with 104 octane booster evertime i re-fill, gettin hondata stage 2 asap then i will dyno..
wuts ue set-up wut u get for horse an torque
same thing for me... After the car heats up a tiny bit it throws the code
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX »</TD></TR><TR><TD CLASS="quote">
same thing for me... After the car heats up a tiny bit it throws the code</TD></TR></TABLE>
Same...
Same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">i'm herd of instances where the EFI (electromagnetic feild interferiance) generated by the curent in ur hedlights goes into the knocksensor wire at the firewall bundle and gives the ecu a crazy signal so it thorws a code. try running the car with out hedlights
at night. i know it's crazy but i'd bet u woulding get a code if that works u can try puting a shealded wire on to protect against EFI</TD></TR></TABLE>
He's not getting the code at night... only during the day.
I think you got it backwards.
at night. i know it's crazy but i'd bet u woulding get a code if that works u can try puting a shealded wire on to protect against EFI</TD></TR></TABLE>He's not getting the code at night... only during the day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX »</TD></TR><TR><TD CLASS="quote">same thing for me... After the car heats up a tiny bit it throws the code</TD></TR></TABLE>
same **** with me too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b2o-vtec »</TD></TR><TR><TD CLASS="quote">would it be easier to get a chipped pr3 with no knock sensor, for the LS-vtec? im going to get a chipped pr3 with no knock sensor when i finish up my set up</TD></TR></TABLE>
Sure you can but make sure the fuel maps and what not matches your set up or you'll be wasting your money... FYI, I started out with a mugen chipped PR3 and ended up selling it for a Stage 2 Hondata...My car was dynoed at 165whp on the chipped pr3 and 192 on the Hondata (CTR cams) last year...
My car was dynoed at 165whp on the chipped pr3 and 192 on the Hondata (CTR cams) last year...</TD></TR></TABLE>[QUOTE=EF_LSVtec]
i want numbers like that wuts ur set-up
yea im getting knock sensor code on my sohc runnming pr3, ive tried alot of things to make the cel go away but then i just gave up and just have to deal with the cel.....btw i beat an evo too, there nothing without there launch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsFrnknstn »</TD></TR><TR><TD CLASS="quote">[QUOTE=EF_LSVtec]
us ITR pistons/stock rods/GSR head, P & P/68TB/match port intake/balance crank/dsm 450/toda C/dtr headers/lite flywheel/hondata stage2=214 whp
I'll try to contact Hondata and find out whats up...it seems that this has been an issue (not really a problem) in PR3/Hondata combo...Besides the annoying check engine light, my car runs fine.
salman
Nov 18, 2008 05:27 AM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
