1990 Accord LX Air pressure in crank case
Old Oct 3, 2004 | 07:51 PM
Petekazel's Avatar
Default 1990 Accord LX Air pressure in crank case
I took off the oil cap today and there is air pressure comming out of the crankcase. I just rebulit the engine because it was smoiking BIG TIME. All the smoke is gone now, but there is that damn air pressure now. Is this normal?
Old Oct 4, 2004 | 06:42 PM
KatyHonda's Avatar
Default Re: 1990 Accord LX Air pressure in crank case (Petekazel)
First make sure the PCV valve and PCV hoses are clear and working correctly. If PCV system is unable to pull a vacuum in the crankcase at idle and you have positive pressure, then you have excessive blowby one of the pistons.
good luck
Old Oct 4, 2004 | 06:48 PM
fast93accord's Avatar
It is 100% normal, when the vehicle is running, and you take the oil cap off, you will feel and hear air coming out.
Old Oct 5, 2004 | 06:20 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petekazel &raquo;</TD></TR><TR><TD CLASS="quote">... I just rebulit the engine because it was smoiking BIG TIME...</TD></TR></TABLE>Isn't it sorta normal to have more blowby until the new rings are seated?
Yes, make sure the PCV system is OK.
Even then, you get air puffing in and out as the pistons move. That feels like it's blowing out, even when it's going equally both ways.
Old Oct 6, 2004 | 03:24 AM
KatyHonda's Avatar
Default Re: 1990 Accord LX Air pressure in crank case (JimBlake)
If PCV system cannot maintain negative pressure at idle, then blowby is excessive. Crankcase pressure does go positive during heavy acceleration when vacuum is low and blowby higher, but not during steady speed or idle.
good luck
pmp
10
Jan 8, 2012 03:59 PM
Lowski
Jul 22, 2007 08:14 AM
stemiched
May 3, 2006 12:14 PM
baPES
Mar 29, 2006 03:33 AM
bluedevil
Mar 24, 2004 08:18 PM
