d16y8 intake manifold
Old Oct 3, 2004 | 07:00 PM
d16rice's Avatar
Default d16y8 intake manifold
How do I tell if the manifold is for a manual or automatic?
Also, what hoses should I use for the coolant line?
Old Oct 3, 2004 | 11:48 PM
Fobtions's Avatar
Default Re: d16y8 intake manifold (d16rice)
autos have no hole in the back for the iacv, its got bolt holes but no vacuum port.
also beware of the manifolds with the air injection, u can tell if it has it by looking at the injector bungs . they have tiny holes drilled in them, and would necessitate jb welding em up or welding em shut.
Old Oct 4, 2004 | 04:43 AM
d16rice's Avatar
Default Re: d16y8 intake manifold (Fobtions)
Don't the automatics have an IACV as well? Is it mounted somewhere else, or just not there at all?
Old Oct 4, 2004 | 05:27 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
there are pics here...
http://www.geocities.com/joeyp....html
Old Oct 4, 2004 | 09:08 AM
d16rice's Avatar
Default Re: d16y8 intake manifold (fastcrxsi90)
That's very informative, thank you.
Since I have an automatic HB, and 'am doing a mini-me, but have a top end off of a EX 5spd. Could I put a cover plate to cover the IACV holes on the back of the intake manifold and then just use my old throttle body (the one from Y7 manifold)?
Would there be any other modifications that would have to be done?
Old Oct 5, 2004 | 08:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">That's very informative, thank you.
Would there be any other modifications that would have to be done?</TD></TR></TABLE>
im guessing you have a d16y7...
if so then yes, you will have to cover up the manual version iacv holes (on the back of the manifold) and use your auto throttlebody with 3-wire iacv.
make a plate and use some sealant cause you dont want a vacuum leak.
- or get an auto manifold....
Old Oct 5, 2004 | 06:04 PM
d16rice's Avatar
That's what I'm planing on doing, but I can't find any aluminum sheets, only steel (which would probably rust after the first car fash). I still have a few hardware stores left to visit, so hopefully, I'll find it there.
Lordofdark176
Oct 13, 2008 06:46 PM
H-adict
Mar 6, 2007 06:04 PM
element_1one
Jul 29, 2003 10:47 AM
fastcrxsi90
Apr 25, 2003 07:08 PM
