camshaft pulley adjustment
Old Oct 3, 2004 | 05:28 PM
crx000's Avatar
Default camshaft pulley adjustment
I have a bomz racing camshaft pulley and i dont know where to adjust for optimal performance. I remember hearing that 16 degrees is stock and that at 20 you can get a couple extra horses. The thing is i need to know where 1 degree starts, is it on the retard or advance side. -thanks
also this is for a '90crx d16a6.
Old Oct 3, 2004 | 05:38 PM
AgentJam's Avatar
Default Re: camshaft pulley adjustment (crx000)
16 degrees is stock ignition timing...0deg is stock for cam.
If you retard the cam timing it should shift the powerband to higher rpm's.
Just mess with it a few degrees at a time and driving it in between.
Vince
Old Oct 3, 2004 | 05:52 PM
crx000's Avatar
Default Re: camshaft pulley adjustment (AgentJam)
so i should try 4degrees to retard from the middle
hondapwr
Jan 4, 2008 09:33 AM
MenaceL.A.671
Sep 13, 2005 04:10 PM
SOHC_MShue
Apr 20, 2005 09:31 AM
89JDMcrx
Sep 25, 2002 05:22 PM
