ecu code
i have a B16 Sir2 motor in my crx. it is throwing code 17. what is code 17 and how can i fix it. please help fast. does anyone have the whole code sheet? if so that would be nice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tbatz »</TD></TR><TR><TD CLASS="quote">i pulled the wiring harness out and i'm going from there.
Good start
Good start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tbatz »</TD></TR><TR><TD CLASS="quote">would that effect the rest of my gauge cluster. i can deal without a speddo.
No speedo, no vtec.
No speedo, no vtec.
I'm I missing something here?
Are you running the stock cable drive type VSS or did you convert to an eletronic tranny mounted VSS and switch out gauge clusters?
Puling out the wiring harness seems really extremeto me especially since you haven't figured out exactly where you should start to fix this problem.
Questions -
does your speedo work or not?
Do you know if you are using the stock VSS system with the cable drive OR have you converted to the electronic VSS in the tranny and a different gauage cluster?
Questions -
IOSUA
11
Aug 9, 2007 08:32 PM
Bseriesy0
Nov 29, 2003 11:46 AM
