New Radiator leaking again
Old Oct 3, 2004 | 03:17 PM
phayzeone's Avatar
Default New Radiator leaking again
I bought a radiator from radiatorbarn.com, installed it and a day later it starts leaking at the top right corner. I called them and they shipped me a new one. Installed that one and it leaks from the same spot! I burped the radiator so that shouldn't be the problem. It's making me mad! I'll give them a call them on monday and see whats up. Could anything else be causing the leaks? I'm thinking since its from the same spot that maybe they had a bad batch or something. Next install i'm going to be putting in a new thermostat and hoses.
Old Oct 3, 2004 | 03:23 PM
moacsupreme's Avatar
Default Re: New Radiator leaking again (phayzeone)
I'm thinking the same thing, perhaps a bad batch from the manufacturer. When you call them, you can simply ask them if they've had any complaints similar to yours. Good luck.
Old Oct 3, 2004 | 03:28 PM
phayzeone's Avatar
People on team-integra said it could be a blown head gasket?
Old Oct 3, 2004 | 03:36 PM
mingbling96's Avatar
Default Re: (phayzeone)
if its leaking from the radiator, it has nothing to do with a blown head gasket. although you could have one, but it wont affect whether or not your radiator leaks or not.
Old Oct 3, 2004 | 03:47 PM
Andyb22g's Avatar
thats weird, im having the same problem, im getting a small leak from the top right or mine to, im going to replace mine this week, ill let you know if it leaks again.
Old Oct 3, 2004 | 03:51 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phayzeone &raquo;</TD></TR><TR><TD CLASS="quote">I bought a radiator from radiatorbarn.com, installed it and a day later it starts leaking at the top right corner. I called them and they shipped me a new one. Installed that one and it leaks from the same spot! I burped the radiator so that shouldn't be the problem. It's making me mad! I'll give them a call them on monday and see whats up. Could anything else be causing the leaks? I'm thinking since its from the same spot that maybe they had a bad batch or something. Next install i'm going to be putting in a new thermostat and hoses.</TD></TR></TABLE>
Did you get the radiator with the plastic endtanks?
Old Oct 3, 2004 | 04:08 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (mingbling96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">if its leaking from the radiator, it has nothing to do with a blown head gasket. although you could have one, but it wont affect whether or not your radiator leaks or not. </TD></TR></TABLE>
Um yes it will. A blown HG will cause the head to lift and build pressure (which will blow out your endtanks). Why didnt you get the all metal radiator it is only $20 more? Did you ever notice the coolant spill over into the overflow tank? Did you replace the radiator cap? I had the same exact problem that you are talking about and my mechanic swore up and down that the HG needed to be replaced. A faulty radiator (that he sold me) cap ended up being the culprit of all of my problems (this guy also told me that he replaced the cap whenever he changed the radiator; I am very skeptical of this also ). I'd try to replace the cap, the thermostat, and the hoses when you replace the radiator. The cap is the 1st thing that I would suspect
Old Oct 3, 2004 | 06:55 PM
mr.beeks's Avatar
Default Re: (FrostyDC4)
if you have a blown gasket check the oil cap
it will have a white gooey build up on it.
did you change the radiator cap also?
dont forget that the stant cap is 20lbs (correct me if wrong)
dont forget OEM cap is rated at 12lbs.
if it is 20lbs just clipp away 1 turn on the spring and that will solve your problem.
Old Oct 3, 2004 | 07:08 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 &raquo;</TD></TR><TR><TD CLASS="quote">
Um yes it will. A blown HG will cause the head to lift and build pressure (which will blow out your endtanks). Why didnt you get the all metal radiator it is only $20 more? Did you ever notice the coolant spill over into the overflow tank? Did you replace the radiator cap? I had the same exact problem that you are talking about and my mechanic swore up and down that the HG needed to be replaced. A faulty radiator (that he sold me) cap ended up being the culprit of all of my problems (this guy also told me that he replaced the cap whenever he changed the radiator; I am very skeptical of this also ). I'd try to replace the cap, the thermostat, and the hoses when you replace the radiator. The cap is the 1st thing that I would suspect </TD></TR></TABLE>
ehh I've heard very bad stories of corrosion with those cheap all metal radiators.
I've been running a CSF replacement radiator w/ plastic end tanks for 20K miles now, no problems.
Old Oct 3, 2004 | 09:49 PM
confucius's Avatar
are your radiator hose looking like its about to explode when you car is warmed up?
looks like a ball park hotdog when its hot?
then something wrong when your cap.
You should get an all aluminum (oem style) radiator.
all edges are welded shut. (oem has some type of clamp holding the plactic top part in place).
I'll sell you one for $185
all black aluminum single core radiator.
forgot what brand. but its all aluminum.
Old Oct 4, 2004 | 07:25 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">ehh I've heard very bad stories of corrosion with those cheap all metal radiators.
I've been running a CSF replacement radiator w/ plastic end tanks for 20K miles now, no problems. </TD></TR></TABLE>
I've been using the Metal radiator for about 2 weeks now and it feels good not to fill the coolant everytime I go out for a drive. Is there anything you can do to prevent this?
My faulty radiator cap killed about three of those plastic CSF replacements
Old Oct 4, 2004 | 08:34 PM
phayzeone's Avatar
Called Radiator Barn and they said the batch of radiators they have are faulty because they have a bulletin on it. So there going to send me a all metal one at no charge.
Old Oct 4, 2004 | 09:03 PM
confucius's Avatar
had my all aluminum radiator for 2 years. nothing wrong with it, still glossy black.
i wouldnt call all aluminum cheap. 90% of the stock radiator is alum.
the plastic top peice is there for a reason. to come apart after soo many miles.
Old Oct 4, 2004 | 09:06 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phayzeone &raquo;</TD></TR><TR><TD CLASS="quote">Called Radiator Barn and they said the batch of radiators they have are faulty because they have a bulletin on it. So there going to send me a all metal one at no charge. </TD></TR></TABLE>
Glad to see you got things sorted out. Radiator Barn definitely has good CS and I wouldn't hesitate to recommend them.
Cannonfairy
Honda Civic (2001 - 2005)
Jun 18, 2015 10:33 AM
flatblack-h22
Jan 3, 2009 08:33 AM
maddcrx
Honda S2000
Jun 7, 2008 10:03 PM
dynastix9
Dec 18, 2005 06:33 AM
speedaholic92
May 9, 2003 06:07 PM
