drivetrain shudder????
Old Oct 3, 2004 | 03:17 PM
darkslide_77's Avatar
Default drivetrain shudder????
hey all,
i have a very weird shudder through my steering wheel at about 55-65mph or so. I am stumped.......checked all four wheels and tires, no problems....both cv shafts are new.....no problems with brakes dragging or anything......????
some help please!
thanks
Old Oct 3, 2004 | 03:21 PM
f22a's Avatar
So you have checked the balance of the wheels? If it just happened when you changed your axles it could be a bad inner joint.
Old Oct 3, 2004 | 03:41 PM
Default Re: (f22a)
all the joints are good........i just replaced the tie rod ends recently....and it had done this to some extent since i bought it last june. i have been told two possibilities.......bad notor/trans mount( have been told tranny mount more than once) and possibly balance shaft belt failure.....but that doesnt sound right. it is only between 55-65 or so on throttle....it pretty much fades away off throttle.....no other vibrations at any other speed or rpm range.....actually now that i think of it, it seens mostly in 5th gear at that speed
thanks
Old Oct 4, 2004 | 05:03 AM
accordion's Avatar
Default Re: (darkslide_77)
I had a terrible vibrating problem at > 60mph on an old car I bought recently. It went away after balancing the tires. The vibration was pretty impressive, I was surprised it could be caused by something trivial like balance.
tsukiyo
Sep 26, 2012 09:05 AM
wannaBjdmca6
Suspension & Brakes
Sep 29, 2010 10:00 PM
tpot90
Oct 8, 2008 05:38 AM
bboixtc
Jun 27, 2007 02:37 PM
ZorinVIII
Sep 29, 2002 06:19 PM
