Click & pops while turning
Old Oct 6, 2008 | 05:38 PM
tpot90's Avatar
Default Click & pops while turning
When the car is moving at a very slow speed, I can hear clicks & pops from my passenger side wheel area. It occurs when turning both left & right. I checked my CV boots, all is well. It still may be the axles, but I was also thinking/hoping for the problem to be the tie rods.
Do you guys have any suggestions or ideas on what it may be?
Model is in my signature.
Modified by tpot90 at 10:06 PM 10/6/2008
Old Oct 6, 2008 | 09:07 PM
tpot90's Avatar
Default Re: Click & pops while turning (tpot90)
BUMP*
please help!
Old Oct 6, 2008 | 10:25 PM
FunnyVictor86's Avatar
i just started having the same problem ... it almost sounds like a bad motor or transmission mount doesnt it? ... i checked my axles too and nothing
Old Oct 6, 2008 | 10:54 PM
tpot90's Avatar
Default Re: (FunnyVictor86)
A motor or transmission mount will act up when there is large amounts of torque being put on them from the engine or tranny. As of right now, my issue actually only occurs at speeds of around 1-2mph, and about idle RPM speeds. I am guessing that its going to become more and more frequent & will occur at higher speeds as time goes on; that is why I want to get this taken care of.
Good luck with your issue, FunnyVictor.
Hopefully someone with a similar issue or some experience in this field can send me in the right direction.
Old Oct 7, 2008 | 05:00 AM
bigjoe53's Avatar
Default Re: (tpot90)
i am having sort of the same problem in my cd5 and i found out it is my lower ball joint. i thought it was the rack and pinion. so you might want to check the lower ball joint.
Old Oct 7, 2008 | 08:27 AM
justin3po's Avatar
id check ur boot very well bc i had that problem and my boot looked fine so i took my wheel off and there was a bunch of grease around the inside of my wheel come to find out there was a small whole in my boot which over time dried it up and made a grinding noise while turning and slower speeds
Old Oct 7, 2008 | 04:55 PM
Launchpad's Avatar
Default Re: Click & pops while turning (justin3po)
Sounds like axles check both boots and make sure they arent torn or punctured
Old Oct 8, 2008 | 05:38 AM
ricebike's Avatar
Default Re: Click & pops while turning (Launchpad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Launchpad &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like axles check both boots and make sure they arent torn or punctured</TD></TR></TABLE>
ummm, he already checked them out...
ball joints on suspension as well as the steering rack ball joints may be the culprits...
wannaBjdmca6
Suspension & Brakes
Sep 29, 2010 10:00 PM
honda305
Mar 9, 2010 08:11 PM
lmananT
14
Oct 28, 2008 04:02 PM
darkslide_77
Oct 4, 2004 05:03 AM
sik96prelude
Oct 21, 2002 07:58 AM
