High rpms
Old Oct 3, 2004 | 02:42 PM
Civichatch27's Avatar
Default High rpms
I finally got my car started but i can get it to idle, the RPM's are way to high. Almost at rev limit. What do you guys think it is?
Old Oct 3, 2004 | 03:24 PM
90crxsib16's Avatar
Default Re: High rpms (Civichatch27)
check vacuum lines and make sure the throttle cable is not binding.....
Old Oct 3, 2004 | 03:26 PM
SiR_Redneck's Avatar
Default Re: High rpms (90crxsib16)
For sure the vacuum lines, i had same problem just mine didnt rev that high wow!
Old Oct 3, 2004 | 03:29 PM
Default Re: High rpms (SiR_Redneck)
alright, ill check first thing in the morning...
Old Oct 4, 2004 | 03:38 AM
I still cant get it to go down. Im stumped, if this will help, its a 91 d15b2 block with a 98 non vtec head.
Old Oct 4, 2004 | 05:08 AM
StupidSlowRSX's Avatar
you must have vaccume lines undone, or holes in them. Check the idle screw too.
Old Oct 4, 2004 | 12:06 PM
Default Re: High rpms (StupidSlowCRX)
does the dpfi manifold have a idle screw? And if it does, where?
Old Oct 4, 2004 | 12:23 PM
lilgreenman's Avatar
Ihad the same problem and i checked everything it ended up being my cold start valve got stuck open
Old Oct 4, 2004 | 12:26 PM
Default Re: High rpms (csc24)
Wheres the cold start valve? And how do i "unstick" it?
i have dpfi
biglebowskicivic's Avatar
i dont know for sure but i never heard of a vacuum line getting your idle that high, are you sure you hooked up your throttle cable right
Old Oct 4, 2004 | 12:27 PM
Default Re: High rpms (biglebowskicivic)
never unhooked it, just changed my head.
Old Oct 4, 2004 | 01:03 PM
johnzm's Avatar
better check your throttlebody plate!
dam man if it starts to rev that high stick ur dam hand over the throttlebody!
and if that does not change anything u better start checkin your gaskets and seals on the IM and vaccum lines behind the TB!@
Old Oct 4, 2004 | 01:11 PM
Default Re: High rpms (johnzm)
ill check my manifold, any idea where the cold start valve on the dpfi is?
weaslehunter1
Jan 26, 2015 03:49 PM
crxnonvtec
22
Sep 3, 2009 02:52 PM
haroldthefly91crx
Mar 31, 2007 02:09 PM
scrubachu
Apr 9, 2005 05:40 AM
DxTrix
Dec 24, 2003 08:59 PM
