Help me break open my tranny casing....
Old Oct 3, 2004 | 02:24 PM
crexer's Avatar
Default Help me break open my tranny casing....
Ok getting no help really in Tech forum so I thought I would try here
My outer tranny case part has a split/crack in it and it needs to be removed and taken to a welding shop for repairs (or just buy a new one). I have the tranny out and just laying in the floor and it is separated from the bell housing about 1". I know there is a plug on the end of the tranny where there is a snap ring that is holding the 2 together and I have gotten the snap ring to come apart. My problem is I forgot to take the ball bearing out and I dont know where that went and now it is stuck open at 1" and wont budge anymore. Someone please help me before i throw a s1 tranny in the woods outside. thanks
Old Oct 5, 2004 | 01:22 PM
crexer's Avatar
Default Re: Help me break open my tranny casing.... (crexer)
someone please help me out there.....this is keeping me from swapping my b16
Old Oct 5, 2004 | 01:45 PM
goforbroke's Avatar
MEAT PATTY
Try to pry it open with wood and a hammer. Wedge the wood between the bell housing and tap on the wood. Work around the housing in a circle pattern.
Old Oct 5, 2004 | 01:48 PM
Gearspeed-Performance's Avatar
Default Re: Help me break open my tranny casing.... (goforbroke)
You can try switching through the gears with the shift selector
Old Oct 5, 2004 | 03:18 PM
4drEF's Avatar
Keyboard Humorist
Just curious - is opening a B series tranny the same as openning a D series?
D series is like;
remove all the housing bolts
remove large plug (takes a socket drive)
-case will seperate a little
-I stick a large flathead between the housing and case to provide constant "opening" pressure
open snap ring until screwdriver falls out (it won't come out unless the snap ring REALLY comes off the bearing shell)
slide off case.
Old Oct 10, 2004 | 08:07 AM
crexer's Avatar
Default Re: (4drEF)
Do you guys think this case might not come off because I have forgotten to take the bearing/spring out? I have removed all the bolts from the casing and I dont see any signs of any bearings or springs and this tranny case been rolled around so many times with me wrestling it that it would have or should have fallen out by now. Exactly what gear am I trying to find for the case to slip off?
Old Oct 10, 2004 | 09:56 AM
B2FiNiTY's Avatar
Default Re: (crexer)
Snap ring?
Old Oct 10, 2004 | 04:15 PM
crexer's Avatar
Default Re: (B2FiNiTY)
i got the snap ring apart...that made the casing slide from a half and inch apart to an inch apart
sloaccord
Mar 23, 2005 10:31 PM
Boosted-Ek
Sep 13, 2003 06:24 PM
phear
Mar 29, 2002 10:46 PM
boomslang
Oct 30, 2001 08:29 PM
