Help.. question about greddy type S and HKS SSQV BOV
Old Oct 3, 2004 | 01:21 PM
hovic's Avatar
Default Help.. question about greddy type S and HKS SSQV BOV
Hi guys..
A friend of mine is interested in one of theese two BOV´s because of the sound :-) The problem is that his boost level is between 1,2 and 1,8 bar. I tried to figure out some details of theese two BOV´s but i didn't succeed.
Would be great if sombody can help me out :-)
By the way.. is it possible to install 2 BOV´s. I think the greddy has a lower boost range than the HKS so can I install 2 greddy´s???
Old Oct 3, 2004 | 11:11 PM
hovic's Avatar
Default Re: Help.. question about greddy type S and HKS SSQV BOV (hovic)
whats up!!! I cannot believe that nobody knows an answer!
Old Oct 4, 2004 | 12:16 PM
hovic's Avatar
bump
Old Oct 4, 2004 | 12:50 PM
aznballer's Avatar
instead of trying to do 2 greddys, u can get the greddy type r which holds more boost
Old Oct 4, 2004 | 12:59 PM
Import_Fan's Avatar
BOVs aren't limited to holding a certain level of boost.
When you have your foot on the gas, the butterfly in the IM is open and so there is a vacuum in the charge pipe. This holds the valve in the BOV shut, regardless of the boost. When you let off the gas and the butterfly slams shut, the would-be compressor surge exits out the BOV that is now being pushed open.
hovic's Avatar
Default Re: (aznballer)
I know but it sounds not good :-( But I can use 2 greddy type S right? I´ve heard that the type S can hold up to 20 PSI of boost. could anyone confirm that?
Old Oct 4, 2004 | 01:02 PM
hovic's Avatar
Default Re: Help.. question about greddy type S and HKS SSQV BOV (Import_Fan)
mh..... and why is the greddy type r or turbo xs RFL for higher boost levels???
Old Oct 4, 2004 | 01:31 PM
Lucky_Smurf's Avatar
It's not so much the boos they can hold, though some have a higher valve pressure than others, it's how much boost can they bleed off quickly so you don't get compressor surge.
Crasian
May 10, 2006 11:14 AM
Integra21
Jun 8, 2005 02:16 PM
vet_girl
Dec 26, 2003 03:14 PM
vtec.dc2
Dec 12, 2002 04:43 PM
VTC_CiViC
Oct 26, 2001 04:47 PM
