Who Knows There Theory/Compression Shit (COMPLICATED!!)
m hoping someone here knows there **** really well enough to answer this question.
Ive got a d16a6 block, not machined or touched at all
There Arias high comp but made a for a d16y8, heres the specs on them.
Displacement: 97.19 1593
Bore: 2.995 75.06
Stroke: 3.394 89.99
Rod Length: 5.394 137.01
Comp Height: 1.154 29.3
Compression: 11.00 11.00
Now from what Ive heard, mating an A6 head to a Y8 block drops compression like a mug right.... But these are like dome pistons, will I slap valves? Its an A6 head milled .040, delta 272 cam and 1 mm oversized valves.
If compression is still nice and up there. Ill go with nitrous, if not Ill go to boost (budget)
Obviously I jsut threw this shitty thread together because Im rather pissed but Ill answer any questions you need to know.
THanks
Modified by 1 Cam Wonder at 1:37 PM 10/3/2004
Bore: 2.995 75.06
Stroke: 3.394 89.99
THanks
