Alignment Question
Just had a small but annoying problem... I recently bought new tires and got an alignment done because my tires were worn and my car was pulling to the right a bit. Well now the tire problem is solved, but even after the alignment, my car is still pulling to the right. I have a copy of the alignment specs before and after and everything is in spec now... Any ideas of what the problem could be. I know there have been a ton of suspension problems with the 02-03 Civic SI's but most of the ones I've seen have to do with creaking noises. Mine is a 02 SI and I have no suspension mods and stock wheels. Thanks for any help or suggestions
hmmm.. you could be right. would that be something I could see by looking at the steering wheel when the car is going straight.. In other words will the H in the middle of the steering wheel be off center if they didnt make sure it was straight. I have to take it back up there tomorrow and have them look at it. What should I have them do this time cause I am assuming the rest of the alignment was done correctly (ex: toe adjustment ect.) I wouldnt have to have them do it all over again right? Just finnish it by adjusting the steering wheel...
WangChung
36
Dec 10, 2003 07:34 AM
