opinion on my motor build-up parts...
So far i have plan on ordering the list of part for my B18B1:
AEBS Headstuds
ACL Bearings Set
CP Piston(9:1 or 9.2:1 Comp)
Golden Eagle Rods
OEM Water pump
OEM Oil pump
Good Year Timing Belt
Those parts im pretty set on, I dont know if i should go with OEM headgasket or go with one that is *made* for boost application, anyone know of a good head gasket?
Is there any other parts that im missing out on this build up?
AEBS Headstuds
ACL Bearings Set
Golden Eagle Rods
OEM Water pump
OEM Oil pump
try using an OEM gasket, and spray it with some copper spray
looks like you have all the main parts, now just have to make sure you have all the small stuff like rear main seal, O-rings, dowel pins, etc... I'm going to make a list of all that crap to make it easier for my next build and save a dozen trips to the dealership...
good luck!
good luck!
http://cgi.ebay.com/ebaymotors...=WD1V
Anyone know anything about that head gasket?
Goodyear timing belt is like a oem supplier or something?
scubacamper
Apr 14, 2015 06:04 AM
Integra Integra
Dec 2, 2005 09:03 PM
