Little Red: My project car (lots of pics)
Old Oct 3, 2004 | 08:32 AM
Chiovnidca's Avatar
Default Little Bastard: My project car (lots of pics)
I picked up this car cheap last winter and am working on it a little bit at a time. Plans are for a stripped down drag race car that is streat legal so it can be driven to the track.
Modified by Chiovnidca at 8:33 PM 4/17/2005
Modified by Chiovnidca at 8:27 PM 10/24/2005
Old Oct 3, 2004 | 08:40 AM
Chiovnidca's Avatar
Default Re: Little Red: My project car (Chiovnidca)
Engine waiting to be installed: D16z6 w/SRP pistons, eagle rods, block gaurd, t3t04e turbo on an ebay manifold and cylinder head porting by me.
Old Oct 3, 2004 | 08:41 AM
Import-Style.de's Avatar
Looks good from outside - but you have to do a lot of work now
Have phun with this car!
EDIT: you want to run the T3/T04e turbo on a D16Z6? Holy sh*** that's for drag race. I run a Turbonetics T3/T04e Turbo on a B18C6 engine - and it isn't to small for that motor.
Old Oct 3, 2004 | 08:54 AM
Chiovnidca's Avatar
I was planning to get the car thru e-check with the original d15b1, but the head gasket was blown and it was using a bit of oil. So out it came.
Motor mount inserts ready to go:
New engine ready to go in:
A d16z6 looks kind of odd with DPFI, doesn't it. It passed e-check that way though. The vice grips were the only thing holding the OBD0 distributor to the engine during the test. The bolt holes didn't line up.
Old Oct 3, 2004 | 09:03 AM
Chiovnidca's Avatar
Default Re: Little Red: My project car (Import-Style.de)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import-Style.de &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: you want to run the T3/T04e turbo on a D16Z6? Holy sh*** that's for drag race. </TD></TR></TABLE>
I've been picking up parts for about a year and a half now. Learned quite a bit in that time, and also think the turbo may be a bit too big now. I'm going to try it anyway though.
Old Oct 3, 2004 | 10:38 AM
UnKnownUser's Avatar
nice
Old Oct 3, 2004 | 12:02 PM
Oh, I think its ok! Turbo will come then around 3500rpm - but very hard then. You can run a lot of boost with this killer!
I'm also learning at this time. Thats the reason why i'm still here. I'm drivin' honda since a half year - and before i've never heard parts like: egt, ecu, wideband .... i was before a opel driver (german cars you know). And now i'm learning some bout tuning for honda and build at the moment 2 of them. Del Sol D16Z6 w/ GReddy Turbokit and the Civic B18 Turbo. Honda is a lot of fun!
And i'm thinkin when your car is done - you will have a lot of fun with that!
Old Oct 4, 2004 | 04:44 PM
drdisco69's Avatar
lol @ vice grips.
Old Oct 4, 2004 | 06:29 PM
sporkcrx's Avatar
Default Re: Little Red: My project car (drdisco69)
That's awesome! Looking forward to future posts
Old Oct 12, 2004 | 04:42 PM
Chiovnidca's Avatar
Default Re: Little Red: My project car (sporkcrx)
Using a perfectly good standard harness and a couple chopped up harnesses from work, here's my version of a OBD0 to OBD1/DPFI to MPFI/VTEC conversion harness. (still need to recover it)
These little bastards are quite roomy when you get some of the extra crap out of them.
Old Oct 13, 2004 | 04:47 AM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
and also think the turbo may be a bit too big now. I'm going to try it anyway though.</TD></TR></TABLE>
Go big or go home
Old Oct 13, 2004 | 01:42 PM
Chiovnidca's Avatar
Default Re: Little Red: My project car (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">
Go big or go home </TD></TR></TABLE>
As long as it gives good boost below 8000 rpms i'll be happy.
Old Oct 13, 2004 | 01:58 PM
Burke's Avatar
Banned
i had a t3/t04e .60 cold, .48 ar hot on a built z6. with no boost controller i was hitting 12 psi at 6500 rpm, with a manual controller i was hitting boost by 4500.
and DAMN did it hit hard!
Old Jan 22, 2005 | 07:07 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: Little Red: My project car (Burke)
Oh ****, it didn't tip over!
Goodluck with it and looking foward to more info as time goes on.
Old Jan 31, 2005 | 07:25 PM
UA6 BALLER STATUS's Avatar
Default Re: Little Red: My project car (turbofienD 04)
looks like fun, I want to see some numbers in the future.
Old Jan 31, 2005 | 08:25 PM
M!lly's Avatar
cars looks good and clean for something you say you got for cheap
Old May 24, 2005 | 03:54 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (CurbinS13)
Status update?
Old May 24, 2005 | 05:38 PM
Chiovnidca's Avatar
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Status update?</TD></TR></TABLE>
Been lazy here lately. Gotta put together some ic piping and a buch of little stuff.
Old Jul 3, 2005 | 02:26 PM
Chiovnidca's Avatar
Default Re: (Chiovnidca)
Update: There's alot more stuff that needed to be done than I thought. Still more to do before it can be driven, but I got it started up yesterday. Sounds and revs alot better than it did with the dpfi on it.
To show some progress:
Old Jul 19, 2005 | 09:23 PM
mportbusta's Avatar
Man SOHC are so cool. Good luk w/ your setup homeboy!!!
Old Aug 1, 2005 | 08:52 PM
Jazzersizer's Avatar
That's bad ***! Keep us updated and good luck!
Old Aug 2, 2005 | 03:25 AM
Chiovnidca's Avatar
Default Re: (Jazzersizer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jazzersizer &raquo;</TD></TR><TR><TD CLASS="quote">That's bad ***! Keep us updated and good luck!</TD></TR></TABLE>
Drove it saturday, tuned to 11psi. It stomps pretty good, more boost as soon as it gets a little cooler out.
With all the little things that had to be fiddled with to get it on the road, it's earned a name change: It's now known as the "little bastard".
Old Aug 2, 2005 | 10:33 AM
Burke's Avatar
Banned
when do you get full boost
ps - CONGRATS
Old Aug 2, 2005 | 10:56 AM
Chiovnidca's Avatar
Default Re: (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">when do you get full boost
11psi @4300 but i'm not sure i got the boost controller set right. I think it may be letting the wastegate start to open a little early.
Old Aug 2, 2005 | 12:07 PM
Burke's Avatar
Banned
thats sounds about right, thats where i was getting that much boost on a t3/t04e but with a .48ar on the hot side with an mbc
