Throttle body query
Old Oct 3, 2004 | 06:50 AM
Redsun's Avatar
Default Throttle body query
Just got a 65mm tb delivered. But on my motor Theres a plug and a sensor but on this new one there isn't what is this sensor and can i bypass it?
This is a pic of the 65mm one, where the circle is thats where the sensor is on mine.
Old Oct 3, 2004 | 07:42 AM
B16A1-EF9's Avatar
Default Re: Throttle body query (Redsun)
You have 92 and up throttle body. Yours has the map sensor on it. The throttle body you received is an older one and is used on cars with map sensors on the firewall. You CAN use it but you'll need an external map sensor from an 88-91 Civic or something.
Old Oct 3, 2004 | 09:45 PM
Redsun's Avatar
Any point in scrwing around to use it? I have an ITR motor so will this 65mm make any difference?
Actually that TB in the pic cam from a 92-95 EG B16A2.
Old Oct 3, 2004 | 10:13 PM
93lsd's Avatar
Default Re: (Redsun)
you can you your original map sensor if you still have just get a piece of vacume hose and put it on your map sensor and then plug it into the one on the throttle body,
have you mic the throttle body yet, because of the pic you have it doesn't really look that big, and if i am wrong the older throttle bodys can only get bore to maybe 62mm because they are not that thick but i could be wrong
Old Oct 4, 2004 | 08:33 AM
Redsun's Avatar
Thanks, so what your saying is the map sensor from mine - take it off, plug a hose into it and plug the other end of the hose onto that pipe where the red circle is, on my piture?
How big are ITR throttle bodies anyway?
And how d'you get your TB so shiny?!?
Old Oct 4, 2004 | 09:02 AM
93lsd's Avatar
yes that will work just fine
Old Oct 4, 2004 | 09:13 AM
PHiZ's Avatar
Default Re: (93lsd)
What is up with the mounting bolt locations inbetween generations (obd0/obd1)?
-PHiZ
Old Oct 5, 2004 | 05:15 AM
Redsun's Avatar
Thanks for the great replies.
atarigamer01
Jul 1, 2008 07:29 AM
yesSiReK
Feb 19, 2008 02:39 PM
spoonJDMteg
Nov 9, 2003 07:18 PM
