engine wont start, seems like it want to but just wont... i need help!!!
hey wassupz, yesterday i just installed my new deck..
and when i finished my car wont start.. it cranks up normally but when i check the pressure guages it doesn't even move. When i turn the car on to start, the engine light stays on and doesn't blink to stay on or not.
i got a few question,
i havent been touching my car because i've been sick, so what i was thinking is that, could there be a shortage? i recharged the battery and had it jump'd but my car still wont start..
could it be the distributor? but how?? burnt coil?
and why does my check engine stay on the whole time from when i push my key to start, normally it comes on's and then stays on or disapear..
any help would be fine. thanks james
Hey, that looks like some porb with the ECM. get it checked at a dealer asap.
At first i though it might have been a battery prob, but then if yor car is cranking normally, then i don't think it's got anything to o with the battery.
Shan2nu
Shan2nu
if anything it sounds like it might be your timing belt. if its cranking over but not turning then its not a battery problem. i bet it just cranks and cranks. check the belt if theres any tension. it shouldnt be loose in any way. if it is, then thats your problem. if thats not it, check to see if youre getting fuel. check the plugs as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aLLmTreK »</TD></TR><TR><TD CLASS="quote">
Does it have any trouble codes stored?
yeah the timing belt seems to be loose just a little bit at time
and i can NOT get it to start, i'm going to check the codes
i checked everything and every plug/etc is in.
it wont start and it's in my garage, this sucks...
i have a fpr and the guages, it seems like its not getting feul because the guages wont go up, i set it at 43psi, i have a b18b motor in it and a obd-2 to obd-1 convertor as well as a obd2 ecu.
could it possibly be feul pump in any way??
i just dont see why when i turn my key to start the check engine light just stays on the whole time, normally it comes on and then goes away or disaapear.. anyone know why?
and what's a ECM?
i also tried to check the engine codes, the check engine light just stays on..
Modified by aLLmTreK at 1:49 AM 10/4/2004
and what's a ECM?
posterchild
Jun 26, 2004 02:09 PM
klassesports
20
Dec 3, 2003 10:52 PM
[626]95-GSR
14
Feb 27, 2003 07:45 AM
