type r alternator
well do they work with each other like can i use one in the other or i can i only use the denso in a gsr and only use the mitsu in the type r...if so do u know why????thanks in advance
This is one of the reasons I don't post in this Forum very much cause someone can't just be mature enough of a person just to merely ask, have you tried to search? They have to get such an immature attitude like it really screwd-up their day to see a certain question posted. But to answer the mans question, I think they might work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Im_In_There »</TD></TR><TR><TD CLASS="quote">im not exatly sure about the unit itself, but the pulley is defenitely different. I guess u can use the gsr altenator and just put the type r pulley on it. good luck.</TD></TR></TABLE>
from my personal experiance you need the type R pulley off the mitsu alternator for the mitsu alternator.
You cant take a denso pulley and put it on a type R mitsu alternator. Ive tried
You can however swap entire alternators w/ pulleys np.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">does one underdrive the alternator?</TD></TR></TABLE>
altn. pulley diameters are the same; I believe its the shaft that the pulley bolts onto that is different.
ITR crank pulley is smaller; thats where you get the underdrive from.
JUNKYARD_R
Appearance Build Threads
Sep 23, 2008 01:11 PM
e
