REBUILT MY MOTOR NOW ONLY RUNNING ON TWO(2) CYLINDERS. :(
I Got My motor fully rebuilt. its is a D16Z6. I am running a OBD0 DIZZY. and OBD0 ECU but only two cylinders will fire. the intresting thing though is that there is a spark on every Plug wire. HELP
Yes they are all pulsing. I removed the plugs. The cylinders that are not firing the plugs are very wet. can it be the valves were adjusted too tight?
check compression in those 2 cyl too. if the plugs are soaked theres probbaly no compression b/c of gas covered cylinder walls.
labtec2
May 25, 2008 05:18 PM
