Boreing out B18C Sir-G
Old Dec 13, 2001 | 12:33 PM
Screamer's Avatar
Default Boreing out B18C Sir-G
What would be the disadvantages of boring out a b18c Sir-G motor to 86mm with the use of new sleeves? This would give me over 2000cc, based on the calculations, but what would be the disadvantage. I am also using Jun stage 3 cams so I do rev the engine to 9000+ rpms.
Thanx
Old Dec 13, 2001 | 12:51 PM
Spade's Avatar
Default Re: Boreing out B18C Sir-G (Screamer)
cost.....can the block go that big? and still be able to cool down?
Old Dec 13, 2001 | 01:20 PM
sgT's Avatar
sgT
would have to get new sleeves first.
Old Dec 13, 2001 | 02:47 PM
Screamer's Avatar
Default Re: Boreing out B18C Sir-G (Spade)
Definitively new sleeves, but, exactly what Spade asked, what about the cooling and engine speeds?
Old Dec 13, 2001 | 08:57 PM
fsarfino's Avatar
gloden eagle sleeves should work fine for cooling I would'nt go w/ anything else
Old Dec 14, 2001 | 09:51 PM
TECH43 RACING INC.'s Avatar
Default Re: Boreing out B18C Sir-G (redteggy)
WE HAVE MANY B SERIES 85MM BLOCKS DRIVING DAILY WITH NO PROBLEMS AT ALL.. FROM STOCK SLEEVED CRV'S (1MM OVER) TO SLEEVED LS'S AND GSR'S...
86MM HOWEVER, IS PUSHING IT AS FAR AS STREETABLE BORE SIZE GOES..YOU WILL HAVE OVERHEATING PROBLEMS DUE TO THE INNEFFICENT BORE TO BORE SPACING....BUT FOR TRACK USE..86 IS FINE..AND WE ALSO HAVE 87 MM B SERIES RACE BORES RUNNNING STRONG.
Old Dec 15, 2001 | 11:50 AM
Screamer's Avatar
Default Re: Boreing out B18C Sir-G (TECH43 RACING INC.)
Yes, I have heard that 85mm is the most one should go for a street/track car. I am not that much into drag racing more so into track racing so there is even more potential for problems with heating, this is why I wanted to hear some opinions. By the way would anyone know what is the ratio of the sleeve to the actual casting between the cylinders? I know that the thickness is 9.2mm, but how thick is the sleeve part and how thinck is the casting part?
gulftiresinc
10
Aug 17, 2004 05:57 PM
rocket256
Mar 2, 2004 08:51 PM
Ruby Civic
Dec 18, 2002 06:43 PM
2point6
Oct 29, 2002 08:55 AM
