weird heat problem.
Old Oct 2, 2004 | 04:38 PM
jdmotorsports's Avatar
Default weird heat problem.
ok, heres the problem. i have a 91 integra with a 98 b18b1 engine. the engine has a lot of mods to it. p&p head, oversized valves, web racing cams, port matched i.m. and over bored t.b., well you get the idea. my problem is there is a TON of heat coming off the engine/head. its to the point i cant hold my hand on the hood if i've been driving for a while. i dont realy need to be runing it that hard either.
i am using the ngk plugs, 7 heat range. is this normal? my engine temp stays normal, i've got new hoses/thermostat. i just dont want to burn the paint on the hood. please help if you can.
Old Oct 2, 2004 | 06:37 PM
b19coupe's Avatar
Default Re: weird heat problem. (jdmotorsports)
My hood gets too hot to touch too, but my ECT reads max 195 degrees, so I would not worry too much. Two
Old Oct 3, 2004 | 12:21 AM
JL's Avatar
JL
how does the a.f.r. look? maybe get a aluminum replacement? flyidyne, koyo, C&R.. or you could try some heat wrap on the header (theres a post on it, just posted to it, but.. forgot if its here or in drag racing) also maybe try a hondata intake manifold gasket.. supposed to lower the intake manifold temp..
Old Oct 3, 2004 | 01:04 AM
Dyn0speed's Avatar
is ur EGR working correctly!
Old Oct 3, 2004 | 05:01 PM
Default Re: weird heat problem. (Dyn0speed)
egr huh? i'll have to look into this. where on the 98 b18b would this be?
i thought it might be that i have a breather filter on the valve cover, but i hooked it up and it made no difference. back to the drawing board.
Old Oct 3, 2004 | 05:26 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">egr huh? i'll have to look into this. where on the 98 b18b would this be?</TD></TR></TABLE>
Next to the muffler bearing. No EGR on 98 B18B.
Old Oct 6, 2004 | 01:08 AM
Dyn0speed's Avatar
yea no egr on my motor too... 99 civic si b16a2... i cant find it
BaseballNut
Honda Civic (2001 - 2005)
Oct 22, 2008 03:16 PM
Extreez
Dec 14, 2005 07:19 PM
AO
Jun 28, 2005 05:43 AM
toadolson
Aug 3, 2004 07:26 PM
KooK
Feb 11, 2002 06:53 AM
