b16 runs, goes into vtec, throws no codes, but doesn't pull
Old Oct 2, 2004 | 03:28 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default b16 runs, goes into vtec, throws no codes, but doesn't pull
Finally got it running, but I had to run it on the D16 injectors because the B16s are broken, I suppose that could be a possibility but I didnt think my injectors were much smaller. Also I think it could be that a vacuum hose is not hooked up correctly, I used this diagram here: http://www.geocities.com/droppedcrxsi/vacuum1.htm , but instead of just one cylinder like the purge, I have two and the one on the right side is unused. I'm going to check my timing in a little but I don't think that would account for how slow it is.
Old Oct 2, 2004 | 03:31 PM
I Have an STD's Avatar
wrenchin'
Default Re: b16 runs, goes into vtec, throws no codes, but doesn't pull (itsallmotor)
injectors are the exact same thing, even with no vacuum, the car should still rip at WOT.
Brett
Old Oct 2, 2004 | 04:01 PM
Default Re: b16 runs, goes into vtec, throws no codes, but doesn't pull (I Have an STD)
its super sluggish, if feel no difference in vtec, it just gets louder, and out of vtec it pulls worse then my d16
Old Oct 2, 2004 | 04:04 PM
Slow89HB's Avatar
Maybe its your clutch slipping.
Old Oct 2, 2004 | 04:17 PM
Rywire's Avatar
Default Re: (Slow89HB)
Dont feel bad just taking out the second solenoid right next to the purge control solenoid. Its not used on the jdm b16.
As far as the power loss, idunno.
Old Oct 2, 2004 | 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow89HB &raquo;</TD></TR><TR><TD CLASS="quote">Maybe its your clutch slipping.</TD></TR></TABLE>
nope, it sounds like the car is misfiring so i got new plugs, we'll see
Old Oct 2, 2004 | 08:06 PM
SoftieB16's Avatar
Default Re: (itsallmotor)
if ur burning gas to fast it might be ur map sensor line crossed thats what happened to me after i fixed the car was a monster
Old Oct 2, 2004 | 09:34 PM
Patch's Avatar
Default Re: (SoftieB16)
Time for a compression test.
Old Oct 2, 2004 | 11:15 PM
Reason's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsallmotor &raquo;</TD></TR><TR><TD CLASS="quote">
nope, it sounds like the car is misfiring so i got new plugs, we'll see</TD></TR></TABLE>
Take off the distributor cap and see if your rotor is loose.
Modified by Reason at 5:54 PM 10/3/2004
Old Oct 3, 2004 | 12:55 AM
slammed00si's Avatar
Default Re: (Reason)
compression and leak down is what i will say. my 00 b16a2 did the exact same thing needed to be rebuilt bad.
Old Oct 3, 2004 | 10:25 AM
abnaasefmb's Avatar
Default Re: (slammed00si)
sounds like timing, mine did the same thing cuz i thought the timing would be set from it last ran. but that was not the case it was retarded to like tdc. set it to 16deg (running n2o) 145 on the dyno. now i have it at 19 and i just retard it before i go to the track.
Old Oct 3, 2004 | 10:30 AM
ghost turtle's Avatar
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">sounds like timing, mine did the same thing cuz i thought the timing would be set from it last ran. but that was not the case it was retarded to like tdc. set it to 16deg (running n2o) 145 on the dyno. now i have it at 19 and i just retard it before i go to the track. </TD></TR></TABLE>
that reminds me... did you change your timing belt during the swap? i didn't and decided to race at the track the night i got it running
it didn't feel like it was pulling like it should so we pulled into the pit and it died suddenly (thank got at idle)
turns out the belt was stretched... i guess that happens when a motor sits for 11 years
good luck, cause after that it pulled pretty hard in vtec.
Old Oct 3, 2004 | 07:41 PM
Default Re: (CRXDX)
thanks for the advice everyone, those are all possibilities and my battery light is coming on and i just got an optima redtop, and the light is still on so i might bench my alternator to see if thats it, unfortunatly the car is at my home in flagstaff and im at school at asu in tempe so i only go home every so often
97reddelsol
May 11, 2013 03:27 PM
exist12
Dec 21, 2007 12:01 PM
ViXoN Hatch94
37
May 19, 2004 04:29 AM
dthrone
Apr 10, 2004 08:15 PM
limpy
Mar 31, 2004 06:19 PM
