OBD0 Oxygen Sensor Question
Old Oct 2, 2004 | 01:55 PM
Steemo's Avatar
Default OBD0 Oxygen Sensor Question
I have a b18a1 in my CRX. I have a stock header with a 1 wire o2 sensor. I want to get the ITR header but the o2 sensor bung is down near the collector where it meets the cat. My question is: will my car run properly with the 1-wire o2 sensor that far away from the engine and heat and if not, is it possible to run a 4-wire o2 sensor while still keeping my crx obd0.?
Thanks in advance.
Old Oct 2, 2004 | 03:05 PM
Steemo's Avatar
Default Re: OBD0 Oxygen Sensor Question (Steemo)
bump
Old Oct 2, 2004 | 11:13 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steemo &raquo;</TD></TR><TR><TD CLASS="quote"> I want to get the ITR header but the o2 sensor bung is down near the collector where it meets the cat. My question is: will my car run properly with the 1-wire o2 sensor that far away from the engine and heat and if not, is it possible to run a 4-wire o2 sensor while still keeping my crx obd0.?</TD></TR></TABLE>
I run one o2 sensor in my dc 4-1 header w/no problems. The o2 sensor is right before the cat.
To run a 4 wire o2 sensor requires an obd 1 conversion.
Old Oct 2, 2004 | 11:43 PM
Steemo's Avatar
Default Re: OBD0 Oxygen Sensor Question (eda6 hatch)
thanks man! hope i have the same results
xci9v8icx
14
Jun 14, 2009 03:58 PM
WhiteOnRice
Jun 22, 2007 01:12 PM
bgoetz
Jun 8, 2005 07:50 AM
acc97lxAndy
Jul 16, 2004 03:20 PM
Import car center
Mar 19, 2004 02:04 PM
