Power output of all motor TODA ???
If this topic has been covered before, real sorry.........anyways...just wondering how much power [typically] would does this set-up yield: [whp and torque] b18c1
Toda Spec C cams, camgears, [w/toda springs, jun retainers], JE 12.0:1 pistons, spoon thin head gasket to raise compression to 12.3:1 port and polish head, skunk2 IM, JDM ITR 2.5 header, Type one 2.5 exhaust, 310cc injectors, exedy clutch and flywheel and tuned with apexi power fc..........Thanks
Modified by E.J. at 11:24 PM 10/1/2004
EXCELLENT CHOICE TO GO WITH THE FC!
I would look for 215-225+ and about 140 ft/lb on a dynojet assuming you have no weak links...
i have a similar build... 12.03:1, Toda B's, Hondata S200, RC310s, AEBS intake mani, Hytech exhaust, Toda header, 70mm TB, other stuff...
Tuned by Tom Payn, results are in the sig
Dont skimp out on the header, its very important... also a good tuner makes all the difference.
