**Honda ECU pin tool for hasport subharness**
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Has anyone here used the honda ECU pin removal tool? Could someone educate me on how to use that ish please.
Nope, I used one of the O-Ring Scribers available from autozone to pop out the pins. You need to remove the white holders in the actual ecu clips and then from the front you push the tool of choice in through the middle hole about one inch and then you push up until you hear an audible click.
Make any sense?
Make any sense?
