question for the itr guys...need help with piston choice
Old Oct 1, 2004 | 04:58 PM
98itr0448's Avatar
Default question for the itr guys...need help with piston choice
I'm rebuilding my itr and have decided to go ls/vtec. I plan on doing JE pistons and Eagle Rods. What JE pistons will I need to net a compression ratio between 11:1 and 11:5:1? I've called several places, but no one seems to know for sure. I only want to build this thing once, so I want to make sure I get it right the first time. Thanks in advance, oh and I searched, but most of the info was reguarding stock or jdm pistons.
Old Oct 1, 2004 | 07:50 PM
bmheck5184's Avatar
Default Re: question for the itr guys...need help with piston choice (98Itr-0448)
why not keep the ITR block and build it? did you put a rod through it or something?
Old Oct 2, 2004 | 03:33 PM
98itr0448's Avatar
bump, anyone konw?
Old Oct 2, 2004 | 05:17 PM
Slow_Em1's Avatar
Default Re: question for the itr guys...need help with piston choice (bmheck5184)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmheck5184 &raquo;</TD></TR><TR><TD CLASS="quote">why not keep the ITR block and build it? did you put a rod through it or something?
</TD></TR></TABLE> exactly...dont go thru the hassle with lS-V, if you want the block just pull the crank from the LS and put it in the gs-r...custome rods and pistons will be needed.
eg4life1202
10
Dec 1, 2018 11:05 PM
VTECth1s
Aug 26, 2006 04:57 PM
ekVtecPower
Jun 22, 2006 09:08 PM
96tegls
23
Apr 28, 2004 11:30 PM
rainmanEK
Jul 17, 2002 09:10 PM
