rinsed engine with water, now hesitate to start....
Old Oct 1, 2004 | 03:41 PM
lakerschamp2000's Avatar
Default rinsed engine with water, now hesitate to start....
98 accord EX v6
i rinsed off engine with water last week
now it is hesitating when i start the car. I just replace all sparklugs and still.
please help me if you know what is going on with my car. thanks
Old Oct 1, 2004 | 03:49 PM
Redsun's Avatar
Default Re: rinsed engine with water, now hesitate to start.... (lakerschamp2000)
If you spray water on your engine then it's most likely your electrical components will stop working. Check your distributor. Spark plugs are no prob cos they won't come in contact with the water. It's the electrical stuff within the engine bay that you need to worry about.
Dude, why did you do it in the first place??!??
Old Oct 1, 2004 | 03:50 PM
Gesundheit's Avatar
Default Re: rinsed engine with water, now hesitate to start.... (Redsun)
My guess would be that something got wet, and then a connection corroded.
Old Oct 1, 2004 | 03:56 PM
Default Re: rinsed engine with water, now hesitate to start.... (Crankdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crankdriven &raquo;</TD></TR><TR><TD CLASS="quote">My guess would be that something got wet, and then a connection corroded.</TD></TR></TABLE>
i checked all the sensors and they are all dry.
i just bought the car and the engine bay so dirty, so i rinsed them off with water.
any other idea?
Old Oct 1, 2004 | 04:26 PM
acy76's Avatar
I would try removing the distributor cap and spraying the inside of the rotor and cap with WD40 (not some other oil -- WD stands for 'water displacing' or similar for a good reason).
JusAccord
Jan 15, 2012 11:03 AM
thunderboy
Jun 28, 2008 06:14 PM
mikael
Jan 10, 2005 05:56 PM
guero2517
25
Apr 2, 2004 12:21 PM
el402
May 19, 2002 04:06 PM
