h22 timing belt tensioner
Old Oct 1, 2004 | 03:14 PM
pgillean's Avatar
Default h22 timing belt tensioner
I have a 2000 prelude with 90,000 miles on it. this weekend i was driving and it started making a rattle noise. I pulled over and cut it off. When i tried to crank it back up it wouldn't start and it sounded like the starter was sticking. I got i towed home and took the valve cover off. I noticed the timing belt wasn't as tight as it should be. I took it to the shop and they told the the belt was fine it was just the tensioner. What do you guys think the chances of it bending valves would be.
Old Oct 1, 2004 | 03:25 PM
Redsun's Avatar
Your valves should be fine, as long as belt doesn't snap!
Old Oct 1, 2004 | 04:43 PM
pgillean's Avatar
Default Re: (Redsun)
it didn't snap but the tensioner went completly out and the marks on the pulleys are far from what its supposed to be
Old Oct 1, 2004 | 06:46 PM
Mike K's Avatar
Default Re: (pgillean)
replace the tensioner, and do a timing belt service while you're at it. i've seen this problem 3 or 4 times before. as a matter of fact, there was a 98 prelude in the shop 2 weeks ago with an engine noise.. turned out to be the tensioner.
btw, it's not the easiest part to replace. if you're not a somewhat experienced mechanic, pay someone to do it.
Old Oct 1, 2004 | 09:58 PM
PrettyLude's Avatar
ever thought about converting it to a manual tensioner? lesser chance to fail
Old Oct 2, 2004 | 07:36 AM
pgillean's Avatar
Default Re: (PrettyLude)
Yeah, there putting on a new timing belt but do you think the valves are bent?
Old Oct 2, 2004 | 09:09 AM
PrettyLude's Avatar
nah, but do you have any experience doing this timing belt job?
ECStarr
Honda Civic (2001 - 2005)
Aug 30, 2012 04:44 AM
tegsr2o3
Mar 24, 2009 02:03 PM
eg6madness
Jan 28, 2008 07:41 PM
bfeils
Mar 24, 2007 10:20 AM
kevtec_00
Jan 19, 2005 03:30 AM
