Where does this plug go?
My radio isnt working. It gets power but doesnt turn on. Im guessing this plug has to complete the circuit. If it doesnt thats fine. I would still like to know where this goes. It comes out of the harness with the plug for the cigarette lighter. Im color blind so I tried to take a pic of the colors on it so you can see them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedvtec92 »</TD></TR><TR><TD CLASS="quote">is this located on the right side of the glovebox?</TD></TR></TABLE>
It is located in the center console where the radio and lighter plug is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mykal »</TD></TR><TR><TD CLASS="quote">The memory wire is hooked up on the radio.
All three plugs are plugged into the heater controls. I dont have a/c. </TD></TR></TABLE>
So do you have anything plugged into the actual A/C switch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">If you are missing that relay, I've got an extra I can send you. Just shoot me an addy in a PM and it'll be on the way. </TD></TR></TABLE>
I ran down and found that relay. Plugged it in and turned the key to ACC. Blew the fuse for the radio. Threw in a 30 amp just to see if it would work. Tried again. Radio came on for about .2 secs and blew the fuse. Thanks for the help and the offer of sending me the relay. Much appreciated.
/me is off to find out how to track down the cause of a blown fuse.
Needs to be About 20% Cooler
THAT'S THE RELAY THAT TURN ON UR CIGERET LIGHTER ON ACC AND OFF WHEN U REMOVE THE KEY IF U WANT UR CIGGRET LIGHTER ON ALL THE TIME CUT ONE OF THE WHITE/GREEN WIRES AND HOOK IT UP TO THE WHITE /BLU WIRE. THE OTHER WHITE/GREEN IS UR RADIO POWER. THE YEL/RED IS UR ACC SIGNAL AND BLK DUH GROUND.
*EDIT* sorry for the caps
garrettrauch
Jul 12, 2011 09:29 PM
Apex i ITR
Apr 15, 2003 04:21 PM
