squeeky noise on left rear ep3
i just got the tein basic coilovers and i ajusted them to the way i liked it and now i am getting a noise from the left rear when i am driving and i hit a bump. please help
I have a si and the same problem I have but in the front, I had Eibach spring, after 8 month I just remove it and install my OEM one back that fixes that noise. I did not try installing a camber kit yet.
You are supposed to tighten up the camber kit with the car on the ground or the rear suspension loaded with a jack. If you don't do it this way the bushing can be stressed and start to rotate in its metal sleeve, this can cause it to squeek when you hit a bump.
i found out what the problem was and fixed it. it was the dust cover and every time i went down it would make a loud noise. so i trimed the dust cover down and the noise stopped. thanks guys for the help.
WildPig
Suspension & Brakes
63
Oct 27, 2005 12:05 PM
