Gas Mileage with AFC hack?
Old Oct 1, 2004 | 05:32 AM
BauleyCivic's Avatar
Risky Business
Default Gas Mileage with AFC hack?
I'm just wondering how horribly the AFC hack decreases your gas mileage (out of boost)?
Old Oct 1, 2004 | 05:34 AM
ladysman's Avatar
Default Re: Gas Mileage with AFC hack? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">I'm just wondering how horribly the AFC hack decreases your gas mileage (out of boost)?</TD></TR></TABLE>
If tuned right it shouldn't. You probably will never know because you will always be in boost.
Old Oct 1, 2004 | 06:38 AM
Happyman's Avatar
Default Re: Gas Mileage with AFC hack? (ladysman)
I used to get about 30 miles to a gallon before then when I got the afchack not beating on it I'd get like 25-27 untuned stock settings(~40 across the board).
Old Oct 1, 2004 | 08:01 AM
beepy's Avatar
My fuel economy has stayed the same with the hack.
My application is a bit different, but if you are still getting 14.5-15.0 AFRs on your wideband while cruising (as you should if you are still OBDII and have it tuned in the right ballpark) then your fuel economy shouldn't suffer.
Of course, my fuel economy goes to **** when I start going into boost often, but usually I am just driving sanely on the freeway.
Old Oct 1, 2004 | 08:08 AM
Bailhatch's Avatar
Default Re: Gas Mileage with AFC hack? (beepy)
I used to get 30+mpg with the hack. still sucked though
USDM 4G VTEC's Avatar
out of boost my mpg is pretty stock like
on boost i run rich like a ****
on the dyno i dipped into lower than 10's for a while, but i noticed the baseline ran between 11's and 13's
Old Oct 1, 2004 | 08:15 AM
boosted-delslow's Avatar
Default Re: (USDM 4G VTEC)
It seems like my car is getting terrible gas milage since i put 440s and the safc on but i think it is cause when ever I drive it we are out beating on it.
Old Oct 1, 2004 | 09:09 AM
Finland's Avatar
Default Re: Gas Mileage with AFC hack? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I used to get 30+mpg with the hack. still sucked though</TD></TR></TABLE>
my sentiments exactly
widewhite
Dec 27, 2014 01:29 PM
TeaAddict
Oct 8, 2004 01:37 PM
freeplay
Oct 13, 2002 07:11 PM
Jesse H
Dec 19, 2001 02:07 PM
PyroVTEC
Dec 2, 2001 04:13 AM
