Wheel Stud Length
Old Sep 30, 2004 | 09:48 PM
f22a's Avatar
Default Wheel Stud Length
What is the stock wheel stud length of an Accord? Is it the same length among all Honda vehicles?
Thanks,
Sean
Old Oct 1, 2004 | 06:23 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Wheel Stud Length (f22a)
Not all honda stud are the same length. On the 5th gen Accord for example the front studs are shorter than the rears because the front doesn't have to come through the rotor. When I did my brake job a couple years ago I replaced all my studs with one from an Acura vehicle, can't remember what model but I have it writen down if interested. I also have the part number writen down as well. Anyways, I did this because I was going to be running Prelude rims for summer daily driving and wanted to run spacers so I didn't rub on anything. So I went to Acura and bought 16 wheel studs and pressed those in.
I want to say they were 5mm longer than the stock rear studs.
I still have all front and rear stock wheel studs at home. I can check the length of them when I get home from work later.
I'm pretty sure the wheels studs on Accords 90-97 were the same. The newer models might be the same as the rear studs from a 90-97 but I'm not sure.
I know when I was at Honda they had some other wheel studs in stock from other Honda models and some of those were the same but I don't remember which ones were.
Old Oct 1, 2004 | 08:45 PM
f22a's Avatar
Thanks bud. That's a big help.
Old Oct 3, 2004 | 02:49 PM
H-T Order of Merit
Default Re: (f22a)
Sorry I didn't get back to you earlier. The two stud lengths for 94-97 Accords is 1.678" and 1.529". The longer one is the one for the rear and the shorter one is for the front. Hope this is what you were looking for.
johng
161
Feb 17, 2010 04:51 PM
timmy0tool
Oct 1, 2007 12:10 PM
yotapup
Nov 7, 2006 11:47 PM
4doorH22
Jun 2, 2002 01:30 AM
