i have a problem on my 1995 d16z6 redline
Old Sep 30, 2004 | 09:26 PM
dcsports's Avatar
Default i have a problem on my 1995 d16z6 redline
wat title says well my redline is always off if im pushing my car my car sometime cuts of at 55 to 6 grand on rpms and its supposed to cutt off at 71 or 72??? my question is how can i fix it ???and if i chip my p28 will it do it still??? lmk
Old Sep 30, 2004 | 10:19 PM
dcsports's Avatar
Default Re: i have a problem on my 1995 d16z6 redline (dcsports)
Old Sep 30, 2004 | 10:30 PM
OpTiX619's Avatar
is your car in limp mode? engine light? oil pressure?
Old Sep 30, 2004 | 10:51 PM
Built to Spill's Avatar
el diablo
Default Re: i have a problem on my 1995 d16z6 redline (OpTiX619)
I wouldnt see why you would chip your ecu unless your motor needs to obtain a higher redline (built block/head) My guess is that your stock tach is slightly off.
Old Sep 30, 2004 | 11:29 PM
dcsports's Avatar
Default Re: i have a problem on my 1995 d16z6 redline (Built2Spill)
sometimes i can go past my rev limit its weird i wanna chip it to rev lil higher 73-74
and when im at the track this problem isnt cool
Old Sep 30, 2004 | 11:32 PM
SECURITY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OpTiX619 &raquo;</TD></TR><TR><TD CLASS="quote">is your car in limp mode? engine light? oil pressure?</TD></TR></TABLE>
peiku's Avatar
is it doing that problem on the stock ecu? if so then your tach might be off. hook up an aftermarket one and compare the two.
Old Oct 1, 2004 | 12:40 AM
dcsports's Avatar
Default Re: i have a problem on my 1995 d16z6 redline (peiku)
this problem doesnt happen all the time it does it mostly if the car isnt warm but even after the car is hott it still does it once in a while not often when its hott
Old Oct 1, 2004 | 08:16 AM
dcsports's Avatar
up
Old Oct 1, 2004 | 09:16 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports &raquo;</TD></TR><TR><TD CLASS="quote">sometimes i can go past my rev limit its weird i wanna chip it to rev lil higher 73-74
and when im at the track this problem isnt cool </TD></TR></TABLE>
blowing up the engine at the track is less cool. Why would you want to raise the limit unless you're making more power up there?
Anyway, on to your problem. If it's an intermittent problem then raising the limit isn't going to help you. I think your ECU is trying to tell you something. Like the others said Any CEL's? How's the oil pressure. Either of these would cause your ECU to go into limp mode and not activate VTEC.
Old Oct 1, 2004 | 09:19 AM
EFz6er's Avatar
Default Re: i have a problem on my 1995 d16z6 redline (nonsense)
Also when your car isnt warm I've heard of people having trouble with vtec
Old Oct 1, 2004 | 09:24 AM
egmike's Avatar
Default Re: i have a problem on my 1995 d16z6 redline (EFz6er)
Vtec does not work when the engine is cold, must be at normal operating temp
Old Oct 1, 2004 | 12:38 PM
dcsports's Avatar
Default Re: i have a problem on my 1995 d16z6 redline (egmike)
yea i know but it still does it sometimes when hott
Old Oct 5, 2004 | 08:17 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports &raquo;</TD></TR><TR><TD CLASS="quote">?</TD></TR></TABLE>
:scratches head as well:
BahrEJ6
Dec 17, 2014 09:46 PM
MI4$DC5
10
Dec 18, 2008 09:22 PM
badassmthr4000
Aug 13, 2007 08:35 PM
zzcoupezz
17
Aug 17, 2006 01:49 PM
dturbo
12
Oct 11, 2005 06:01 PM
