water leaks inside my 99 civic hb
Old Sep 30, 2004 | 09:02 PM
kalvin916's Avatar
Default water leaks inside my 99 civic hb
does anyone have the same problem as i do? when it rains water leak inside the car. Does anyone know how to fix this problem?
Old Sep 30, 2004 | 09:05 PM
Built to Spill's Avatar
el diablo
Default Re: water leaks inside my 99 civic hb (kalvin916)
Welcome to the wonderful world on Hondas
Old Sep 30, 2004 | 09:10 PM
-Gambit-'s Avatar
Default Re: water leaks inside my 99 civic hb (Built2Spill)
its a really common problem with 96-00 hatches, the water comes in from behind your taillights. You might want to change the little foam rubber seal behind your tails
Old Sep 30, 2004 | 09:11 PM
JDMisGOOD's Avatar
gotta love the hatchy's!
Old Sep 30, 2004 | 09:26 PM
EK k kay's Avatar
Default Re: water leaks inside my 99 civic hb (JDMisGOOD)
Yup leaks in my 99 hatch too. It's on the driver side tail light for me. I'm wondering does honda sell replacement rubber thingys behind the tail lights?
Old Sep 30, 2004 | 09:34 PM
JDMFreak's Avatar
Default Re: water leaks inside my 99 civic hb (chowmien)
hehe i have the same problem when it rains, i heard you replace the foam or a rubber seal vent near the rear bumper...i could be wrong but you replace something back there heheh some do it and give up part number and a write up plz!
Old Oct 1, 2004 | 12:19 AM
kalvin916's Avatar
Default Re: water leaks inside my 99 civic hb (JDMFreak)
well if it leaks from the back then how come my car leak from both the front driver and passenger sides?
Old Oct 1, 2004 | 12:43 AM
99CivicExCoupe's Avatar
cross your fingers for a recall
Old Oct 1, 2004 | 05:36 AM
Ka chao's Avatar
it could be a recal or it might be leaking from your heater core
Old Oct 1, 2004 | 06:16 AM
spork2's Avatar
First, what you need to do is pull off your tail lights, and clean them off.
then, clean the foam gasket that is placed between car and lights.
next, apply 1/4 inch bead of hondabond around the opening where your lights set against.
Then let hondabond dry completely!!!!!!!!!!YOU MUST LET HONDABOND DRY COMPLETELY OR YOUR LIGHTS WILL BE STUCK TO YOUR CAR!!!
Before reinstalling lights apply foam gasket to back of light and reassemble.
Not only will you still be using all honda parts, but the bead of hondabond will act as shield an redirect water away from the opening!
**** luck!!!
Old Oct 1, 2004 | 06:21 AM
ecahatch's Avatar
Senor Miembro
Default Re: water leaks inside my 99 civic hb (Geeky_Gambit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geeky_Gambit &raquo;</TD></TR><TR><TD CLASS="quote">its a really common problem with 96-00 hatches, the water comes in from behind your taillights. You might want to change the little foam rubber seal behind your tails</TD></TR></TABLE>
yep....i have to do this soon
Old Oct 1, 2004 | 06:42 AM
PLAN:B's Avatar
Default Re: water leaks inside my 99 civic hb (spork2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork2 &raquo;</TD></TR><TR><TD CLASS="quote">...Then let hondabond dry completely!!!!!!!!!!YOU MUST LET HONDABOND DRY COMPLETELY OR YOUR LIGHTS WILL BE STUCK TO YOUR CAR!!! **** luck!!! </TD></TR></TABLE>
I'm guessing this happened to you?
Thanks for the write up bro...i'll be doin' it soon.
Old Oct 1, 2004 | 06:44 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kalvin916 &raquo;</TD></TR><TR><TD CLASS="quote">well if it leaks from the back then how come my car leak from both the front driver and passenger sides? </TD></TR></TABLE>
Are you saying it's leaking from around the firewall/footwell area?
If so, I know exactly what your talking about. On my 92 hatch I noticed my passenger side floormat was damp one day but didn't think to much about it until I went to get gas one day and the pump didn't stop and shot gas all over the fuel door area so they gave me a free car wash. SO as I was getting the car washed I noticed a couple drips come from under the clove box and land on the floormat. Does this sound similar to your problem?
I just fixed the problem last weekend and washed the car yesterday and no more leaks. I did take pictures on the procedure but haven't had time to download them from the camera and do the write-up yet. I'll get to that write-up done asap if anyones interested. I should have it posted sometime next week, the weekend might be to busy.
Let me know if anyone is interested.
Old Oct 1, 2004 | 08:08 AM
kalvin916's Avatar
Default Re: water leaks inside my 99 civic hb (TouringAccord)
Im intersted in it.... yep that the same thing that happen in my car.
Old Oct 1, 2004 | 08:19 AM
EK22snatch
Guest
Posts: n/a
w0rd. ek hatches get 0wn3d by rain!
H-T Order of Merit
ok, I'll get that as soon as I can.
Old Oct 1, 2004 | 08:21 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork2 &raquo;</TD></TR><TR><TD CLASS="quote">Then let hondabond dry completely!!!!!!!!!!YOU MUST LET HONDABOND DRY COMPLETELY OR YOUR LIGHTS WILL BE STUCK TO YOUR CAR!!! </TD></TR></TABLE>
Heck yes, more new people who actually help. And I couldn't help it, but that made me laugh.
nonsense's Avatar
if it's in the front then check the seal between the front cowl and the windshield.
Old Oct 1, 2004 | 08:56 AM
H22JEFFREY's Avatar
were does it leak threw!
Old Jan 7, 2005 | 03:27 PM
SyDuck's Avatar
Default Re: water leaks inside my 99 civic hb (hybridvisionz)
back from the dead but im currently having this problem. where do i get hondabond? any substitutes for it?
Old Jan 7, 2005 | 03:31 PM
civic_speed99's Avatar
My coupe leaks around the drivers tail light
Old Jan 7, 2005 | 03:40 PM
86si's Avatar
windsheild replaced? common water leaks are from improperly sealed windsheilds!
Old Jan 7, 2005 | 04:21 PM
99hatch's Avatar
Default Re: water leaks inside my 99 civic hb (86si)
the whole driver side of my hatch is soaked with water. it only goes about half and inch up the carpet but it starts to smell funky after a while and the ladies dont like that. i have no freakin idea where it comes from but its really annoying and its obviously not drying because, well its never completely dry in there!!!
where is it coming from?!?!
Old Jan 7, 2005 | 04:25 PM
Econo'Box's Avatar
Default Re: water leaks inside my 99 civic hb (99hatch)
Use silicon sealant on the tail lights.
Old Jan 7, 2005 | 11:16 PM
SyDuck's Avatar
Default Re: water leaks inside my 99 civic hb (tabrisakakaoru)
alright thanks
